Re: wiring 95 Corolla
On Mon, 10 Apr 2006 16:13:12 -0700, wags wrote:
[color=blue]
> My car was broken into and they ripped the wires off the rear window
> defogger switch when they pulled the radio console. Now I don't know
> which wire goes where! Went to the local dealership and they didn't
> have the wiring diagram for my model. Their diagram showed 3 wires and
> mine has five. They said a tech would have to trace each wire down
> (sounds too expensive). Where can I find a wiring diagram for a 95
> Corolla, built in Canada with a 7A-FE engine, to just hook up the wires
> again?
> thanks in advance[/color]
Hmmmm...try calling Customer Care. It will take a while.
I'm surprised, because when my Corolla GTS got ripped, the dumb-asses did
the same thign, and all they had to do was unhook the homemade harness I
made (at an Aircraft OEM parts manufacturer, using aircraft style
connectors) and the local Toy dealer was able to get me the correct wiring
diagram, with the color codes.
He probably gave you the first one he came across. Try another dealer.
In the grand scheme fo things...
What difference does it make?
