Re: Transmission problem 92 Toyota Camry
"Pandamsu via CarKB.com" <u16226@uwe> wrote in message
news:5ebe40184ad9e@uwe...[color=blue]
> Thank you answering my questions Ray O. I have a couple more questions for
> you. By choosing to ignore this problem, am I setting myself up for a
> larger fix later? What would be involved with repairing this condition as
> it
> exists presently?[/color]
Just to clarify, delayed engagement when the engine and transmission are
cold is not a problem but once the automatic transmission fluid is up to
operating temp, there should be no more than a 1.2 second delay from neutral
to drive or neutral to park. A delayed engagement at operating temp is
indicative of low line pressure (front pump worn or clogged channel
somewhere) or a worn clutch. One of the things that brings this condition
on is shifting from drive to reverse or vice versa before bringing the
vehicle to a complete stop.
I remember seeing a technical service bulletin issued in the 1980's about
delayed engagement when the engine and transmission are cold and to be
honest, I don't remember what the cause or remedy were, but I believe it
involved changing a check ball or something in the valve body.
I would keep mental track of the engagement time and see if it remains
constant or gets worse. It will probably get worse over time but it may
take 5 years or more. Given the age of the vehicle, I wouldn't worry about
2 or 3 seconds when you first start up, especially if the air temp is pretty
cold and there are no other abnormal symptoms with the transmission.
As I mentioned before, if the ATF hasn't been changed in a while, it would
probably be a good idea to have it changed although I wouldn't bother with a
power flush or anything, just a straight fluid change.
Good luck!
Ray O
[color=blue]
> Ray O wrote:[color=green][color=darkred]
>>> In recent weeks I have noticed the transmission on my 92 Toyota Camry
>>> has
>>> started to slip. I bought the car two years ago when it had 142,000
>>> miles[/color]
>>[quoted text clipped - 17 lines][color=darkred]
>>> Is this transmission slipage or could this be something else? What is
>>> the
>>> fix for this? I would like to get by as cheaply as possible.[/color]
>>The symptom you're describing is referred to as delayed engagement, more
>>of
>>an annoyance than a problem. Fluid is draining back and has to be
>>re-filled. It is repairable but if you're waiting to wait an extra couple
>>of seconds, it is not worth the effort.
>>Go ahead and change the fluid as a maintenance item.
>>[color=darkred]
>>> Thank you in advance for your response.[/color]
>>[/color]
> Message posted via CarKB.com
> [url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200604/1[/url][/color]
