Re: Corolla 96 1.8Engine, Start Problems
"Flyer729" <Alec.Subero@gmail.com> wrote in message
news:1144801532.686475.131920@t31g2000cwb.googlegroups.com...[color=blue]
>I just replaced the starter and still has the same problem. Its not the
> battery and its not the starter, what could it be???[/color]
As I mentioned before, starter grinding noises generally are caused by a
problem with the bendix not engaging the pinion with the flex
plate/flywheel, bad pinion gear, or bad flex plate if you have an automatic
transmission or flywheel if you have a manual transmission.
You can remove the starter and apply power to the starter from the battery
with jumper cables and see if the pinion gear extends all the way.
If you are getting grinding noises, remove the starter and take a look at
the teeth on the flex plate/flywheel. If the teeth are OK, have someone
turn the engine over with a wrench on the lower crankshaft pulley (make sure
the ignition is off!) while you inspect the teeth. You may want to mark the
starting point with a marker so you don't make your friend do more work than
necessary.
If you are not getting grinding and just an intermittent start, check the
battery clamps, cables, ground cables, and starter relay and relay contacts.
Ray O
