check engine light came on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 07:52 PM   #1 (permalink)
liza
Guest
Posts: n/a
View liza's Photo Gallery
I recently got my oil change like i regularly do in Feburary and had my
mechanic ck out the engine as well. everything was cked out okay. this
last saturday i noticed the ck engine light came on and it has not gone
off since. i cked the gas cap to see if it was on tightly and it was.
it still continued to be on. does anyone have suggestion on what i can
do to take that thing off or do i need to take it in to someone to ck.
i really dont want to pay anything to do it. please help thanks.
Old 04-11-2006, 07:53 PM   #2 (permalink)
liza
Guest
Posts: n/a
Re: check engine light came on
sorry its a 2001 toyota corrolla S btw sooo sorry im rushed and worried
at the same time
Old 04-11-2006, 07:53 PM   #3 (permalink)
liza
Guest
Posts: n/a
at the same time
Old 04-11-2006, 07:57 PM   #4 (permalink)
timbirr@mailcity.com
Guest
Posts: n/a
View timbirr@mailcity.com's Photo Gallery
You really need to have it checked. Odds are it is nothing too terrible
that about $270 won't fix. LOL.
Lots of auto parts stores will check it for free in hopes of you buying
the part to fix it from said parts store. Call around. One national
chain that USUALLY does this is AutoZone.
But, unless you pretty much know what to do with the information, or
really trust whatever advice is thrown you at the parts store, it still
doesn't help you much.
I would prefer to have my mechanic check and then give me the "good
news."
Old 04-11-2006, 11:13 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"liza" <liza0183@hotmail.com> wrote in message
news:1144799551.615944.81600@i39g2000cwa.googlegroups.com...[color=blue]
>[/color]
You will need an OBD II code scanner to determine why the check engine light
came on. Your mechanic should have one, or as timbirr suggested, some parts
stores will scan the codes for free.
Once you have the codes, you can post the code numbers (not the parts
store's interpretation of the codes) here for some more advice.
Some emissions components have a longer warranty than the powertrain
warranty so depending on what is wrong, it may be better to take it to a
Toyota dealer for repair.
Ray O
Old 04-15-2006, 12:17 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
What the others have said ...
AutoZone stores will allow you to pullthe codes yourself, or they will pull
them for you for free. (I encourage you to do it yourself, it's very easy
and you can do it in under 5 minutes.)
Go to AutoZone (other car parts stores probably have Loaner Tool Programs
too) and get the OBD II Scan Tool. They will hold your driver license as
security if you want to use the tool in the parking lot, or they will sell
the tool and give a Full Refund later if you want to take the tool home and
use it in your garage. Either way, there is a data port along the bottom
edge of your car's dash board, roughly in the area over your left leg while
you are driving (some cars have a cover over the data port, in which case
the cover must be clearly labelled as the data port). Plug the scan tool
into the data port, and turn the ignition to ON, but not Start. The codes
will be displayed, and the scan tool can reset them after you have made a
list.
In another post, you said you have a 2001. My guess is that you need a new
O2 Sensor. Replacing this part is similar to replacing a spark plug -- it
takes the same skill set and nearly identical tools.
>[/color]
Old 05-01-2006, 07:17 PM   #7 (permalink)
Guest
Posts: n/a
View liza0183@hotmail.com's Photo Gallery
okay i found out what my code is by going to Autozone and getting the
diagnostic. this is my code: P0171. k guys what is this mean? tomorrow
i have an appt with my mechanic to ck it out. i hope it is not that
much. below the code thing it said "too lean". help me out pls. thanks
Old 05-01-2006, 07:27 PM   #8 (permalink)
Guest
Posts: n/a
Could be a number of things. I had the same problem and cleaned my MAF
with a $3.49 can of electrical contact cleaner (even though the
manufactuer "forbids" this practice) and haven't had a problem since.
The following web site explains the code a little better....if the
suggestion be to replace the MAF, ask about cleaning it instead -- it's
nice to do the "forbidden" everyonce in a while....
[url]http://www.obd-codes.com/trouble_codes/generic/p0171-system-too-lean-bank-1-oxygen-sensor.php[/url]
Old 05-01-2006, 07:45 PM   #9 (permalink)
Guest
Posts: n/a
how would i do that? im a gurl and love to figure stuff out by myself.
but i probably cant i guess i will wait till what my mechanic says :( i
will post what happens when he calls also so i can get feedback.
Old 05-01-2006, 07:58 PM   #10 (permalink)
Guest
Posts: n/a
Well, you already got the mechanic lined up and I hate to see a working
person lose money, so I would suggest going along with it
now...especially since it could be something else....
However, two cavets, if the mechanic can't for certain convince you the
problem has been isolated somewhere else, you can't mention cleaning
the MAF before they go and start replace idle sensors, O2 sensors, etc.
By the way, they may WANT to replace the MAF, since most makers
recommend replacement rather than cleaning -- but you should talk them
into cleaning instead.
Cleaning it is simple, although there are a couple of gotcha's/ If
you are interested "google is your friend" as someone else around here
loves to say....try plugging in the totally foreign phrase "cleaning
MAF" LOL
Old 05-01-2006, 08:02 PM   #11 (permalink)
Guest
Posts: n/a
[color=blue][color=green][color=darkred]
>>>[/color][/color][/color]
OPPS I miswrote:
I meant to say "however, a cavet, if the mechanic can't for certain
convince you the problem has been isolated somewhere else, you should
ask about cleaning the MAF before they go and start replacing idle
sensors, O2 sensors, etc."
Old 05-02-2006, 01:20 AM   #12 (permalink)
Ray O
Guest
Posts: n/a
news:1146525461.684328.187650@j73g2000cwa.googlegroups.com...[color=blue]
>[/color]
It would be helpful if you quoted previous posts so people know what kind of
symptoms the car has and what year, model, mileage, the car is.
P0171 means that the system for Bank 1 is too lean. The most common cause
of this condition is an O2 sensor that is only marginally working. A
competent technician can check the O2 sensor output and confirm this.
Ray O
Old 05-02-2006, 02:18 PM   #13 (permalink)
Guest
Posts: n/a
k guys my mechanic called this is what is wrong; the air filter was
extremely dirty leaving the MAF very dirty as well. They replaced the
air filter and cleaned the MAF the light came off they said if it comes
back on it the next couple of days or weeks to take it back to them
cause it possible can be the O2 sensor but they cked and it was fine.
So in total it cost me 169.19 (including a oil change that i needed).
what you think ?
Old 05-02-2006, 03:47 PM   #14 (permalink)
Guest
Posts: n/a
Oh, I don't know, I hate to second guess mechanics, and I don't know
how involved they got checking vacuum leaks possibilities, etc.
An oil change can edge on $30. Cleaning the MAF would probably edge on
a half-hour shop time. So, now you are talking $60-70.
Air Filter is no big deal, but you probably got charged a separate
charge for it, even though they basically had it out when they did the
MAF work -- so around $50 for that (just guessing that a ultra high end
filter would be $30). So, with tax, license, destination charges that
could be pretty close.
So, while it was no discount job, I can't say they took you to the
cleaners.
Of course, doing it all yourself, you would have hit about $30 (not
including your laborLOL).
Old 05-03-2006, 04:01 PM   #15 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
<liza0183@hotmail.com> wrote in message news:1146593901.431040.224230@j73g2000cwa.googlegroups.com...[color=blue]
> what you think ?
>[/color]
That sounds right to me.
BB code is Off
Smilies are Off
[IMG] code is Off
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 02:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 11:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 12:52 PM
Check Engine Light clp86rom Archived Corolla threads 13 06-17-2006 10:02 PM
