Help! I got both P0170 and P0330 codes on my 95 v6 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2006, 09:08 PM   #1 (permalink)
95v6camry
Guest
Posts: n/a
View 95v6camry's Photo Gallery
Help! I got both P0170 and P0330 codes on my 95 v6 Camry. P0330 points
to the knock sensor #2. Was hoping I could replace it myself saving
some money. Do you think that will fix the problem with both codes? Any
advice is greatly appreciated.
Old 04-13-2006, 07:09 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Help! I got both P0170 and P0330 codes on my 95 v6 Camry
"95v6camry" <mike_t_trinh@yahoo.com> wrote in message
news:1144890483.927198.42540@z34g2000cwc.googlegroups.com...[color=blue]
>[/color]
Diagnostic Trouble code P0170 means fuel trim malfunction in bank 1.
DTC P0330 means Knock Sensor 2 Circuit Malfunction (Bank 2)
The two DTC's are not really related and there is no 1 thing to replace that
will cure both trouble codes. Also, i may be wrong, but I would imagine
that P0170 would be accompanied by another DTC indicating whether the fuel
trim is lean or rich.
the knock sensor affects ignition timing and does not have anything to do
with fuel mixture. Check continuity for the wire harness for the knock
sensor on bank 2.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
