Toyota Landcruiser II - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2006, 03:28 PM   #1 (permalink)
ZhangLu
Guest
Posts: n/a
View ZhangLu's Photo Gallery
It's a 22R engine, the idle was not smooth and difficult to get started
when the engine is warmed up/hot.
Recently changed the carburetor, convert to electronic ignition but the
engine does not seemed to perform up to expectation.
Is there any other things that I should check?
Old 04-14-2006, 12:15 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota Landcruiser II
"ZhangLu" <Dr.chongff@gmail.com> wrote in message
news:1144956500.483037.260950@i39g2000cwa.googlegroups.com...[color=blue]
>[/color]
Check the carburetor setup, including the float level and choke operation.
Make sure that the fuel line is not routed over the exhaust manifold and all
heat shields are in place. Check for manifold vacuum leaks.
If you are still having problems, start with the basics, air, fuel, and
spark at the appropriate times and if it still doesn't start, have the car
put on an exhaust sniffer.
Ray O
Old 04-16-2006, 03:02 PM   #3 (permalink)
ZhangLu
Guest
Posts: n/a
The carburetor is okay, the engine can easily get started when it's
cold. There's no problem during cruising, even at high speed. The
problem started when the engine is hot/warmed up.
Idle gets a bit shaky and diffucult to start. What's wrong?
Old 04-16-2006, 11:46 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:1145214167.894712.11380@t31g2000cwb.googlegroups.com...[color=blue]
> Idle gets a bit shaky and diffucult to start. What's wrong?[/color]
There are several possible causes, and the best way is to start with the
basics - air, fuel, ignition at the appropriate times.
Have someone measure manifold vacuum when the engine is hot to check for
vacuum leaks.
Check to make sure that the choke pulloff is working properly and check the
fuel level in the sight glass on the side of the carburetor.
Check to make sure that idle speed is set correctly and the correct
carburetor is installed with the correct jets.
Make sure all heat shields on the fuel line are in place.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota to Offer XM Radio as a Factory-Installed Option EKam Toyota News 1 08-17-2011 07:53 PM
2006 Yaris: Toyota Canada Announces Nameplate For New Global Subcompact rolla-XRS Toyota News 34 12-03-2005 12:48 AM
