Mystery oil consumption - 2002 Highlander V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2006, 06:50 PM   #1 (permalink)
Bud H
Guest
Posts: n/a
View Bud H's Photo Gallery
I have a 2002 Toyota Highlander V6 with 130,000 miles which had exhibited
negligible oil consumption between oil changes -- that is, until about a
month ago.
Just as I was arriving home from work, I saw the low oil pressure light blip
on for a moment. When I checked the oil level, I found almost nothing was
showing on the dipstick!
I refilled it to the full line and have been monitoring it every few days,
checking it first thing in the morning before starting to make it easy to
see the oil on the dipstick.
It is using about 1 quart of oil (Mobil 1 synthetic - I've used synthetic
oil since the 10,000 mile mark) every 5,000 miles now after using nothing
during the first 120,000 miles. There are no visible leaks, and I don't see
anything unusual with the exhaust to show oil consumption.
Any idea where the 1 quart of oil every 5,000 miles is going?
Bud H
Old 04-15-2006, 08:13 PM   #2 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
Re: Mystery oil consumption - 2002 Highlander V6
Into one or more of the cylinders WBMG
mike hunt
"Bud H" <budh@REMOVETHISwmis.net> wrote in message
news:1242u5hquerju5d@corp.supernews.com...[color=blue]
>month ago.
> blip on for a moment. When I checked the oil level, I found almost
> nothing was showing on the dipstick!
> see anything unusual with the exhaust to show oil consumption.
> Bud H
>[/color]
Old 04-15-2006, 09:09 PM   #3 (permalink)
Dave Dave
Guest
Posts: n/a
View Dave Dave's Photo Gallery
you say you have 120,000 miles on the it. one qt every 5000 miles is
nouthing to worry about.you are proubly not going to see any blue smoke
at that rate.just drive it and make sure you keep an eye on it.some
brand new cars (not toyotas) might burn that much in 5000 miles. if you
are changing it every 5000 miles that is about right.
Old 04-17-2006, 02:14 PM   #4 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Bud H" <budh@REMOVETHISwmis.net> wrote in message news:1242u5hquerju5d@corp.supernews.com...[color=blue]
>I have a 2002 Toyota Highlander V6 with 130,000 miles which had exhibited negligible oil consumption between oil changes -- that
>is, until about a month ago.
> Just as I was arriving home from work, I saw the low oil pressure light blip on for a moment. When I checked the oil level, I
> found almost nothing was showing on the dipstick!
> I refilled it to the full line and have been monitoring it every few days, checking it first thing in the morning before starting
> to make it easy to see the oil on the dipstick.
> It is using about 1 quart of oil (Mobil 1 synthetic - I've used synthetic oil since the 10,000 mile mark) every 5,000 miles now
> after using nothing during the first 120,000 miles. There are no visible leaks, and I don't see anything unusual with the exhaust
> Bud H[/color]
Shoot, if it helps any I have a Toyota C&C truck that runs fine and burns a quart of oil every 400 miles or so.
I know its hard to believe but its always done that because the loads so heavy. Basically runs wide open it's whole life.
Oh, and it pass's the California smog test's.
Dan
Old 04-22-2006, 01:54 PM   #5 (permalink)
William Hayes
Guest
Posts: n/a
View William Hayes's Photo Gallery
> month ago.[/color]
[snip][color=blue]
> Any idea where the 1 quart of oil every 5,000 miles is going?[/color]
Change from Mobil 1 to Straight 30 Weight for 30,000 miles, the striaght
weight will re-seal the heads with the usual goo, allowing you to go back to
using Mobil 1 for another 130,000 miles. (Change the oil filter when
appropriate)
BB code is Off
Smilies are Off
[IMG] code is Off
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 05:32 AM
V6 Gen 3 Oil Leak? Stangar 3rd & 4th Generation (1992–1996 & 1997–2001) 14 08-15-2005 05:07 PM
Highlander Hybrid Suv Will Make Canadian Debut In Montreal rolla-XRS Toyota News 4 01-14-2005 01:29 AM
About Oil and Gas for 2005 Camry V6 liuhais 5th & 6th Generation (2002-2006 & 2007-2011) 43 12-03-2004 10:24 PM
Synthetic Oil for the Camry 2002 LE V6 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-26-2002 01:45 AM
