Source for seal on ignition coil - 2002 Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2006, 10:16 PM   #1 (permalink)
jim
Guest
Posts: n/a
View jim's Photo Gallery
I changed my spark plugs but lost one of the seals between the
ignition/spark plug coil and the valve cover. I thought I could buy
one easily, but I guess its not so simple. Toyota tells me its part of
the coil and to get it I'd have to buy the $90 coil. I suppose I could
just run a bead of silicone (and I presume the purpose of the seal is
to keep water and grime out of the tube, so silicone would probably
work fine), but if there's a source for these little rubber seals,
could somebody let me know. It looks like I can buy a spark plug tube
seal, but it seems that this seal is the seal that's under the valve
cover.
Thanks.
Jim
Old 04-16-2006, 12:03 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Source for seal on ignition coil - 2002 Sienna
"jim" <jacked_72@yahoo.com> wrote in message
news:1145153800.101588.283800@t31g2000cwb.googlegroups.com...[color=blue]
> cover.
> Thanks.
> Jim[/color]
It looks like Murphy's law applies here. As soon as you apply a bead of
silicone, the seal that you lost will turn up stuck to one of the cross
members or splash shields. If you decide to go the silicone route, I would
recommend using one that does not harm O2 sensors, like the stuff used for
form-in-place gaskets.
If you know the diameter of the seal, how about looking for a similar one in
the plumbing supply section of a hardware store? The rubber may or may not
hold up as well as the one made for the coil.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Do the Ignition Wires and Coil Packs ever need changing? Ken4 Camry & Solara Lounge 16 12-16-2005 08:24 AM
Question/Help about Ignition Module and Coil TheOtherSide Camry & Solara Lounge 3 09-27-2005 08:29 PM
MSD ignition coil - safe for MR2? StuckInNeutral MR2 Forum 10 10-12-2004 10:08 PM
Ignition Coil from Toyota Dealer fetus Toyota Dealers 4 02-12-2004 08:23 PM
