2002 Tacoma - Replacement Tabs for Cup Holder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2006, 08:08 AM   #1 (permalink)
doyle.steve@comcast.net
Guest
Posts: n/a
View doyle.steve@comcast.net's Photo Gallery
The little rubber tabs in the cup holders of my 2002 Double Cab Tacoma
have dried, cracked and broken. The dealer says that if I care enough I
have to replace the entire console at some ridiculous price.
I just want to replace the little rubber tabs. They should not cost
more than about $2 each (and even that would be too much!).
If anyone knows where I could buy these, I would love to hear from you.
Thanks in advance.
Old 04-16-2006, 09:28 AM   #2 (permalink)
bbtaco
Guest
Posts: n/a
View bbtaco's Photo Gallery
Re: 2002 Tacoma - Replacement Tabs for Cup Holder
<doyle.steve@comcast.net> wrote in message
news:1145189309.769338.84100@i40g2000cwc.googlegroups.com...[color=blue]
> Thanks in advance.
>[/color]
Call [url]www.trdparts.com[/url] and order the tabs or a different local dealer may
order them for you. They should only be 7 to $8 shipped to you. Or some
people have made replacements using a mouse pad, simply lay the old tabs on
the mouse pad and cut to match with scissors. It is easy to change out the
tabs. If your center console is like mine (02 TRD extended cab) then it's
actually got 4 screws and 2 bolts in it. The first two are one on each side
in the front where it screws into the gear shift cover, then move both seats
all the way forward and there's one screw in each back corner. Then open the
bottom storage compartment and there's two 10mm bolts in the very bottom.
Each tab is held in place by a single phillips screw. Hope that helps....
bbtaco
Old 04-16-2006, 06:32 PM   #3 (permalink)
Guest
Posts: n/a
Great - I will give them a call!! Thanks.
BB code is Off
Smilies are Off
[IMG] code is Off
2002 Tacoma Timing Belt replacement fajkus1 1st Generation (1995.5–2004) 12 12-30-2010 08:43 AM
Tacoma stock leaf springs need replacement bill70 1st Generation (1995.5–2004) 10 10-04-2007 02:07 AM
New 2002 Tacoma Owner :) Winters 1st Generation (1995.5–2004) 1 12-16-2004 01:11 AM
2002 Tacoma Indiglos? whoagorgeous 1st Generation (1995.5–2004) 2 09-16-2004 09:02 PM
Reese hitch for 2002 Tacoma Nicolas 1st Generation (1995.5–2004) 0 03-06-2003 02:00 PM
