1998 Corolla ,The airbags are not functioning. Neither is the drivers side lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 06:01 PM   #1 (permalink)
VijaKhara@gmail.com
Guest
Posts: n/a
View VijaKhara@gmail.com's Photo Gallery
Hello,
I intend to buy a 1998 Corolla. mileage: 100k. The problem is The
airbags are not functioning. Neither is the drivers side lock. I ran
Carfax's history of the car, and it has a clean title.
I don't have experience about automechanics. Can you please tell me if
these are serious problems? +Can you guess if that car has some
accidents but they are not recorded in Carfax?
+Can you estimate how much I should pay to replace airbags and repair
drivers side lock?
Thanks
Old 04-17-2006, 06:11 PM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: 1998 Corolla ,The airbags are not functioning. Neither is the dr
The door lock may not be a big deal - worn out actuator, loose control rod
- the door panel needs to come off to see what the problem is. As far as
the airbags - how did you determine that both need to be replaced?
Old 04-17-2006, 06:20 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1998 Corolla ,The airbags are not functioning. Neither is the drivers side lock
<VijaKhara@gmail.com> wrote in message
news:1145314896.713025.280120@i39g2000cwa.googlegroups.com...[color=blue]
> Hello,
> drivers side lock?
> Thanks
>[/color]
Whether a non-functioning driver's side lock and airbags are serious or not
depends on your definition of serious.
The car will run without a driver's side door lock and without air bags but
obviously, the passengers do not gain the benefit and security that these
items offer.
It is impossible to guess if the car has been in an accident that has not
been recorded in Carfax without looking at the car. It is very possible
that body repairs have been performed without being reported to Carfax.
Most body repairs are pretty obvious to a trained eye so the best way to
find out is to have a knowledgeable person look at the car.
The cost to replace the air bags and repair the driver's door lock can be
anywhere from $200 to $5,000, depending on what is wrong. Unless you are
very knowledgeable about diagnosing and repair an air bag system, I would
not recommend purchasing a vehicle with a problem in the air bag system. I
also would not ask the seller to repair it before selling it to you because
he could merely unplug the supplemental restraint system warning light and
you would never know that you do not have an air bag until after a severe
accident.
Pass on this car and look at another one.
Ray O
Old 04-19-2006, 01:26 PM   #4 (permalink)
VijaKhara@gmail.com
Guest
Posts: n/a
thank you very much.
BB code is Off
Smilies are Off
[IMG] code is Off
1998 Camry Drivers side window wind noise Clean SE-R 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-02-2011 10:46 AM
