92 4runner shifts very hard - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 09:54 PM   #1 (permalink)
habersetzer@gmail.com
Guest
Posts: n/a
View habersetzer@gmail.com's Photo Gallery
Ok, I'm reeeeally hoping I can get some good feedback on a problem I'm
having w/ my 92 4runner. The problem is that it shifts extremely hard
between gears, as if there was nothing to smooth the transition between
gears. It's an automatic. It's not that it shifts at a high RPM,
causing the shift to be hard. It shifts hard no matter what RPM it
shifts at. It used to only do this about 10% of the time. Now it's
doing this about 90% of the time. If it's not shifting hard, I cannot
figure out how to make it shift hard. It has nothing to do with the
EFT Power button, the OD button, or temperature of the engine or the
air. It seemed pretty random when it did this only 10% of the time.
I've changed the transmission fluid and filter screen - no improvement.
I'm thinking it could be the torque converter, but I don't know much
about those.
I also notice that when it's cold, it tends to wait until a high RPM
before shifting into second gear. This has gotten progressively worse
as the shifting hard has gotten worse...maybe related?
Any advice would be appreciated. I just hate to dump money into it
until I have a good idea of where the problem likely is.
Thanks,
V
Old 04-20-2006, 12:00 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 92 4runner shifts very hard
<habersetzer@gmail.com> wrote in message
news:1145501674.488036.50440@e56g2000cwe.googlegroups.com...[color=blue]
> about those.[/color]
Harsh shifts are generally associated with a bad accumulator. They are
usually not to difficult to change in a RWD or 4WD vehicle.
[color=blue]
> as the shifting hard has gotten worse...maybe related?[/color]
What is cold? Is it the ambient air temperature or the coolant temperature?
The transmission is designed to delay shifts when the coolant temperature is
cold and will not shift into OD until the coolant is warmed up.
Does the temp gauge operate normally and does the engine warm up within a
reasonable amount of time? If the temp gauge doesn't work properly, check
the connection at the temperature sender near the thermostat. If the engine
takes a long time to warm up, check the thermostat.
[color=blue]
> Thanks,
> V
>[/color]
Good luck!
Ray O
Old 04-20-2006, 11:50 AM   #3 (permalink)
Guest
Posts: n/a
Bad accumulator, eh? I haven't heard of that part before...hope it's
in my hanes manual. Thanks for the info! Regarding the cold
temperature, I'm referring to the engine / transmission temperature.
It can be 80 degrees outside, but when I first start the engine and
leave the driveway, it revs very high before finally shifting into
second (and it's a very hard shift at that). Feels like I have a shift
kit installed.
The temp guage works great, and the engine warms up normally.
Thanks,
H
Old 04-20-2006, 01:29 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:1145551802.654464.319300@i40g2000cwc.googlegroups.com...[color=blue]
> kit installed.
> Thanks,
> H
>[/color]
An accumulator is basically a shock absorber for the transmission.
If you are familiar with driving a manual transmission, you know that shifts
are smoother if you gradually engage the clutch and jerkier if you engage
the clutch very quickly. Contrary to what many people believe, the clutch
will last longer if you quickly engage the clutch instead of gradually
engage it. The same is true of automatic transmission accumulators.
Getting some shift shock from an automatic transmission is not harmful to
the transmission.
The high revving you're getting when you first start the engine and leave
the driveway sounds like a condition known as delayed engagement. This
condition will tend to become more pronounced as the transmission ages,
especially in cooler weather. There are a few causes to this condition,
like wear in the transmission pump and wear or damage to a piston seal.
This condition does not necessarily need immediate attention, but you can
prolong the transmission's life if you engage reverse or drive and let the
truck creep for about 15 or 30 seconds before revving the engine.
I suspect that these 2 conditions appear in vehicles under 200,000 miles if
the driver shifts from drive to reverse and vice versa before bringing the
vehicle to a complete stop, like when backing out of a driveway or parking
spot. A friend of mine will back out of his driveway, apply the brakes, and
then shift into drive when the car is almost but not quite stopped, and he
has had transmission problems on just about every vehicle he has owned with
an automatic transmission including a Dodge Colt, Cressida, Camry, and
Windstars.
Ray O
Old 04-20-2006, 04:16 PM   #5 (permalink)
Guest
Posts: n/a
Makes sense. Thanks a lot for the explanation. I'll try driving
slowly for about 30 seconds to see if it finally shifts into second w/o
revving it. I've only owned this vehicle for the past 4000 miles (it
currently has 96k miles on it), so I can't vouch for the past drivers'
habits. I've found a transmission place that will connect a "scanner"
to it for free to see if it's an electrical problem. Not sure if it
is, but free to find out.
-H
Old 04-20-2006, 10:03 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1145567781.941770.146520@z34g2000cwc.googlegroups.com...[color=blue]
> -H
>[/color]
If the "OD Off" light is flashing, then it is worth scanning the codes from
the transmission electronic control unit (ECU). If the OD Off light is not
flashing, then no codes will be stored so it's not worth scanning for them.
Ray O
Old 04-21-2006, 07:46 AM   #7 (permalink)
Guest
Posts: n/a
Ok, I'm not getting any lights on the dash. Only the feeling of
getting rear ended when it shifts from gear to gear. Will the OD Off
light flash even if it's not an OD-related thing?
Thanks!
H
Old 04-21-2006, 02:24 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:1145623603.877677.174560@i40g2000cwc.googlegroups.com...[color=blue]
> Thanks!
> H
>[/color]
A flashing OD Off light is the electronically controlled transmission's
version of the check engine light. On a newer vehicle with OBD II
diagnostics, the check engine light takes care of transmission malfunctions
as well.
If the OD Off light is illuminated and not flashing, then OD gear is locked
out and the transmission is in effect a 3-speed transmission instead of a
4-speed.
Ray O
Old 04-21-2006, 05:20 PM   #9 (permalink)
Guest
Posts: n/a
Ok, thanks for the info! I'll let the mechanic see what he can find,
and then decide if I can afford the repair cost. I noticed today that
the hard shifting seems to go away when the engine is warmed up. Not
sure if that's a consistent behavior, so I'll pay attention over the
next few days to see if that's the pattern. If it's related to engine
temp, would that give any clues as to the problem?
Thanks,
H.
BB code is Off
Smilies are Off
[IMG] code is Off
Disconnecting '92 4Runner Alarm daved 4Runner Lounge 3 03-03-2007 02:15 PM
help buying a 4runner!! Snip3r 4Runner Lounge 8 11-01-2006 01:46 PM
Replacing front cv axles on a 92 GTS, how hard? SLC Punk Celica Forum 4 06-01-2002 11:57 PM
