Bumper cover removal 98 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2006, 01:40 AM   #1 (permalink)
98camry98
Guest
Posts: n/a
View 98camry98's Photo Gallery
I have a 98 camry that needs the bumper cover replaced and i'm gonna do
it myself.I was just wondering what tool do I need to take the bumper
off? I have located all the screws I believe,but it was just a quick
check and i'm not sure what i would use to unbolt them.
Thanks
Old 04-21-2006, 01:01 PM   #2 (permalink)
98camry98
Guest
Posts: n/a
Re: Bumper cover removal 98 camry
Anyone?
Old 04-21-2006, 02:15 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"98camry98" <stunnaman@gmail.com> wrote in message
news:1145601600.875410.114960@u72g2000cwu.googlegroups.com...[color=blue]
> Thanks
>[/color]
Toyota bumper covers are generally as easy to remove as they appear to be.
There is a bunch of bolts holding the skin on. I believe that a 10 mm
socket will fit.
Ray O
Old 04-22-2006, 09:19 AM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
You didn't say what damage was but the plastic covers can be repaired. Its
worth investigating before you install an aftermarket one that doesn't fit
properly. I'd disconnect the battery while doing it incase you triger the
air bag sensor! Trial fit the new one and then have it primed and painted
with paint that has a flex additive. Most likely it has a foan absorber
behind it hat will have to be replaced too.
> Thanks
>[/color]
Old 04-23-2006, 08:34 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
"Wolfgang" <NOwolfXgang_dieterxSPAM@NOXcox.netNOT> wrote in message
news:0%q2g.8940$_z2.8254@dukeread02...[color=blue]
> Its worth investigating before you install an aftermarket one that doesn't
> fit properly. I'd disconnect the battery while doing it incase you triger
> the air bag sensor! Trial fit the new one and then have it primed and
> painted with paint that has a flex additive. Most likely it has a foan
> absorber behind it hat will have to be replaced too.[/color]
I wouldn't worry about triggering an air bag sensor unless you intend to
pound on the front of the bumper with a board or sledge hammer. There are 3
air bag sensors, and at least 2 out of the 3 must detect a crash
simultaneously before the air bag deploys.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
HOWTO remove the rear bumper cover on a 2003 camry? cas 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-27-2011 11:59 AM
Removal of 4runner bumper cover drunken_panda 4Runner Lounge 0 03-13-2006 02:02 PM
Camry 98 rim cover rajul 3rd & 4th Generation (1992–1996 & 1997–2001) 0 06-09-2004 09:16 AM
A-pilar cover removal Fever Camry & Solara Lounge 7 06-03-2004 11:53 PM
