1995 Landcruiser bearing noise? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 02:25 PM   #1 (permalink)
nakayayamot
Guest
Posts: n/a
View nakayayamot's Photo Gallery
After the death of 92 Previa, I purchased a used 95 Landcruiser.
Bought from a Toyota dealer with full history and limited warranty. Has
155,000 miles.
I've noticed a slight whine which only occurs from between 45 to 70 mph
and only when under load.
Very quiet when coasting.
Hard to pinpoint location but from the drivers seat, seems like from
the front seat area to the back of the vehicle.
No vibration, just annoying whine.
I test drove a 97 landcruiser yesterday for comparison and noticed less
of a whine, but definitely a whine from under the vehicle.
Is this a pinion bearing problem or am I just too sensitive to the
normal driveline noise from these big trucks?
Old 04-23-2006, 08:59 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1995 Landcruiser bearing noise?
"nakayayamot" <lechon@hotmail.com> wrote in message
news:1145733930.764245.303570@j33g2000cwa.googlegroups.com...[color=blue]
> 155,000 miles.
> normal driveline noise from these big trucks?[/color]
The location of the sound suggests that the source is the transmission,
transfer case/center differential, or driveshaft support bearings (if
equipped with a 2-piece driveshaft). Whining sounds are generally caused by
either bearings or gears. If the other LandCruiser you test drove also has
the same sound, I wouldn't worry about it.
Ray O
(correct punctuation to reply)[color=blue]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Help...excessive road noise islandx Tercel, Paseo, Starlet, and Sera Forum 5 02-01-2006 05:08 AM
Excessive wind noise 2005 Tacoma psmerdon 2nd Generation (2005+) 12 09-26-2005 03:18 PM
Transmission Pinion Bearing noise zotparkerm Camry & Solara Lounge 3 09-26-2005 01:00 PM
Rear Wheel Bearing Noise LoneReefer2005 Archived Corolla threads 0 07-26-2005 10:28 PM
whine/chirp noise coming from engine block...bearing?? shackelton Camry & Solara Lounge 4 09-16-2004 02:23 PM
