CD melted in a Scion CD player? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 05:28 PM   #1 (permalink)
nolabab@gmail.com
Guest
Posts: n/a
View nolabab@gmail.com's Photo Gallery
This winter, a friend of mine had part of a CD melt in her Scion's
player. It melted in a 1/2" wide circular band about 2.75" across while
it was playing.
Is this something that only happens in Scions, or is it some freak
occurance which is just as likely with any player? I know I've never
seen anything like this before.
Old 04-22-2006, 06:33 PM   #2 (permalink)
Wickeddoll®
Guest
Posts: n/a
View Wickeddoll®'s Photo Gallery
Re: CD melted in a Scion CD player?
<nolabab@gmail.com> wrote in message
news:1145744921.244185.213660@u72g2000cwu.googlegroups.com...[color=blue]
> it was playing.
>[/color]
My husband leaves CDs in his xA all the time, all year round. No CD has
even been damaged, much less melted.
Natalie
Old 04-22-2006, 07:14 PM   #3 (permalink)
View bineabble's Photo Gallery
need help
I think I messed up big time. Here is my story.
I have a 98 white camry, it had alot of scratch marks, dirt that couldn't be removed, and oxidation all over. So I took the 2000 grit sandpaper, and wetsanded the car, all the scratches are now gone, it's perfectly smooth however it is very dull, no shine at all.
so i took it to a local detailer, assuming that a wax shop would bring back the shine. however, he informed me that he can't preform any detailing becuase the clear coat has been stripped off the car.
what should i do now? the paint is in very good condition, it's just missing the clear coat.
should i go to maaco and let them spray clear coat on it?
thanks
bineabble is offline
Old 04-23-2006, 01:17 AM   #4 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sat, 22 Apr 2006 20:14:24 -0400, bineabble
<bineabble.26oxqz@no-mx.forums.yourdomain.com.au> wrote:
[color=blue]
>should i go to maaco and let them spray clear coat on it?[/color]
You could - but I'd go a bit further to make sure you only have to
do it once. When you sanded off the destroyed clear-coat, you may
have taken off enough of the paint layer to make trouble later -
luckily, that's the whole idea of the clear-coat, to protect the paint
underneath. You don't want to pay to have it clear-coated, and then
spot the areas where the grey primer is starting to show through...
I'd have the painters buff out the color coat again to prepare the
surface and get all the oil and wax off, put one healthy new color
coat on (or two thin ones), bake it, then shoot fresh clear coat on
top and bake again.
Shouldn't cost that much more, and you'll be good for another 10
years at least...
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 04-23-2006, 12:52 PM   #5 (permalink)
Geoff Miller
Guest
Posts: n/a
View Geoff Miller's Photo Gallery
bineabble <bineabble.26oxqz@no-mx.forums.yourdomain.com.au> writes:
[color=blue]
> couldn't be removed, and oxidation all over.[/color]
Your car is only a '98, and its paint is already in that sort of
condition? Why do people allow their cars to deteriorate like
that? I've never understood that. The things aren't that dif-
ficult to take care of, cosmetically. I'd never buy such a car,
if I saw one for sale used. If the parts of the car that were
easily visible had been so badly neglected, I'd have to wonder
what had been neglected mechanically.
[color=blue]
> is very dull, no shine at all.[/color]
You had the right idea in principle, but you should've used
polishing compound instead of sandpaper.
There are two products that are similar and are often confused:
polishing compound and rubbing compound. Both can be found on
the car-wax shelves at your local auto parts store. They come
in flat, circular plastic containers, just like car wax does.
Both are abrasives suspended in a semisolid base. The difference
between them is that polishing compound has a much finer grit than
rubbing compound does. For that reason it should be used first. If
it doesn't get a scratch or stain out, then go to rubbing compound.
That way you'll know you're removing the least-possible amount of
paint or clear coat in order to get the job done.
[color=blue]
You could just wax it, preferably with some high-quality wax that
would last for awhile. Having it clear-coated would be a good
long-term approach, though.
Geoff
"Support Darwinian evolution -- squash a weakling today."
-- David Wren-Hardin
Old 04-23-2006, 09:18 PM   #6 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Sat, 22 Apr 2006 20:14:24 -0400, bineabble wrote:
[color=blue]
> thanks[/color]
MAACO?!?!?! Find a good local body shop.
But what I can't figure out is, how did a melted CD do that to your paint?
In the grand scheme fo things...
What difference does it make?
BB code is Off
Smilies are Off
[IMG] code is Off
Scion VIP @ NHRA Spring Nationals - Englishtown, NJ - May 7 ScionVIP Scion Events 1 05-12-2006 02:53 PM
Factory slave CD player laxer49 Audio, Video, and Security - Tech 2 01-23-2006 09:57 AM
stock slave CD player skynyrdmh Audio, Video, and Security - Tech 3 10-21-2004 09:28 AM
