Re: Surprise - TWO quarts of oil from low to high on the dipstick (was After not using any oil before, dipstick surprisingly shows no oil in engine)
"Bud H" <budh@REMOVETHISwmis.net> wrote in message
news:124n00sgparbkb5@corp.supernews.com...[color=blue]
> "Bud H" <budh@REMOVETHISwmis.net> wrote in message news:...[color=green]
>> 2002 Toyota Highlander Limited Edition V6, engine and transmission 3.0
>> liter 24-valve VVT-i V6 Automatic, bought in December, 2001 and now has
>> 127,000 miles.
>> After using synthetic motor oil during most of the vehicle's life, today
>> I saw the oil warning light blip on for a fraction of a second just
>> before arriving at work. After checking oil level, I learned I had NO
>> indication on the dipstick! The last oil change had been 7,000 miles
>> earlier with Mobil 1 synthetic.
>> Every time I have changed the oil in the past, it has been very close to
>> the original level with nearly zero oil usage. Now out of the blue,
>> there is no level and indications of some sludge in the area under the
>> gas cap.
>> No leakage noted on the ground and no leakage evidence near the drain
>> plug or oil filter. Oil was changed today and vehicle driven almost 100
>> miles. No problems at all in engine performance and oil level.
>> Anyone ever experience something like this before where engine oil usage
>> is WAY higher than it is normally?
>> Bud H
>>[/color]
> It took 4,000 miles for level to go from the high to low mark on the
> dipstick.
> A surprise, however. It took TWO quarts of oil to fill from the low to
> high mark. Something I was not expecting. (All levels taken on level
> ground first thing in the morning before the vehicle was started.)
> So the oil consumption rate is 2,000 miles per quart of oil, not 5,000
> miles per quart as I thought previously.
> Bud H[/color]
Oil capacity, including filter, is 5.0 quarts.
