Toyota Carina Running Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2006, 09:52 AM   #1 (permalink)
testrun
Guest
Posts: n/a
View testrun's Photo Gallery
I was wondering if anyone can help.
I have a toyota Carina auto 2.0L Gli 1996/7 model, really good reliable
car, however I am having intermittent problems.
When the car has been driven on a long journey it start to give
problems when I come to a standstill where the idling speed drops,
fluctuates before cutting out. It does retsart straight away but have
to leave the car off for about 5 to ten minutes before the idling
stays normal.
Since the problem is intermittent the garages are reluctant to start
changinging components as they are not sure what the problem is.
Is there a condensor unit attached to the distributor in this car as I
personaly think it could be something like that. Howver I cant see one
anywhere.
Can anyone advise.
Thanking you for your cooperation.
Old 04-23-2006, 09:28 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota Carina Running Problems
"testrun" <anjumosman@gmail.com> wrote in message
news:1145803957.437712.34970@j33g2000cwa.googlegroups.com...[color=blue]
> stays normal.
> changinging components as they are not sure what the problem is.[/color]
You might want to invest in a vacuum gauge and monitor manifold vacuum when
the condition occurs to see if there is an intermittent vacuum leak. I've
run across vacuum switching valves that have a very minute crack that only
opens up when the engine is very hot.
Another possibility is that fuel delivery is being disrupted somewhow.
Has the engine check engine light come on?[color=blue]
> anywhere.
> Can anyone advise.
> Thanking you for your cooperation.[/color]
Condensers are pretty much a thing of the past in modern vehicles with
electronic ignition.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
surpercharge 3VZ-FE possible? gmfb3VZ-FE Hardcore Tech and Competition 24 04-26-2010 09:24 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
I just found this article your comments on this? dario Camry & Solara Lounge 18 07-26-2005 09:39 PM
Toyota Recall Look Here! John Chen General Discussion 0 05-26-2005 11:02 PM
Discount on all TWM Toyota Short Shifters! TWM Performance General Discussion 0 05-19-2005 09:20 AM
