This post (hopefully to become a thread) is a follow-up to the (very
short) thread "1987 Corolla SR5 steering repair--need help from
experienced mechanic" that I started after my recent (fortunately
not-too-bad) collision with this car. The steering is now repaired, but
the close inspection I did during that repair found a few new problems.
Since (like Hachiroku) I love this car (a "hachiroku", i.e. an AE86), I
am determined without a doubt to repair everything that is wrong with
it, even if it costs several thousand dollars (US). (The logic for this
is that I can't imagine finding another car I'd be as happy with for
several thousand dollars). However, right now I'm looking at repairs
(recent past and recent future) which I expect to come in at around
$1,000 US total, including the steering repair of the previous thread.
By the way, my car has only about 104,000 miles on it.
If all goes well, this will be the first in a series of threads that I
will start about a series of repair projects that I have planned to do
on this car this summer. About half of these stem from the recent
accident and/or a hard pot hole strike the left front wheel took about a
month or two earlier, mentioned in my previous thread. The others are
projects through the winter I had been planning to do once the warmer
weather came (and I had saved some money by working through the
winter). Here is a list of all of them, prioritized:
1. damaged suspension control arm --accident repair * starting with
this post *
2. front left wheel bearing noise --pot hole strike-related?
3. body work (fender and bumper) --accident repair
4a. A/T output shaft lateral play and leak --pending thru winter
4b. vibration at speed: driveshaft imbalance? --pending thru winter
5. valve stem seals & tailpipe smoke @ warm-up --pending thru winter
And, if all goes well with the projects above, I will tackle:
6. when cold until warmed up: runs rough, stalls, related issues
Some of these issues are further described (incidentally) in the
explanation of the dynamics of the collision at the end of this post.
Now, to address the control arm, the main subject of this post. When
repairing the left steering tie rod, I did a detailed inspection of the
front left suspension, comparing against the right side, and I
discovered that the end of the control arm outboard of the strut bar
(which triangulates the control arm) was bent rearward, with its rear
edge bent upward. In the ball joint, the neck of the ball might also be
slightly bent; I did not remove the boot to inspect it. I have learned
that the control arm and ball joint are an indivisible factory unit, so
that the ball joint will have to be replaced with the control arm
anyway. The strut bar is OK and was not stretched; on both sides of the
car, I measured the distance between the staked nut and the first hole
in the strut bar and found it to be 14-5/8" (right on spec, within the
accuracy of the measurement).
A local dealer parts department (Central City Toyota on Chestnut St. in
Philadelphia) wants $212 US for the part. Because of the high price, I
am considering buying a used part, either salvaged stock or U-pull-it.
However, I am slightly concerned about the unknown of a used ball joint
regarding durability and reliability. I need advice: Is it worth the
$212 for a new control arm and ball joint vs. a used unit with unknown
mileage wear and lubrication history? Can I expect a used ball joint to
last the 100,000 more miles that I want the car to last? If a used part
may be a good idea, should I only accept one I can inspect first (for
example from a U-pull-it yard), and if so, how should I inspect it?
After writing the last paragraph, I have also found the part new at
ToyotaPartSales.com (Dallas Toyota) at a discounted price of $150.
(They list $212 as the MSRP.) They will ship within the continental
US. Any caveats/words of caution? If I buy new, I'll probably go this
way.
Also, are there any things to watch out for when replacing the control
arm? I know it's recommended to bounce the suspension a few times
before final torquing of all fasteners, and I'll do that. Anything
else?
Finally, here are the physical dynamics of the collision, that I have
deduced, which caused the damage to the left front suspension and
steering: The collision flattened my left fender from its leading edge
back to the wheel, exposing the front of the wheel. The exposed leading
edge of the forward-pointed wheel then hit the other vehicle, and the
wheel was wrenched outward, bending and cracking the internally threaded
tube of the steering tie rod end (a.k.a. the outer tie rod). The
rearward force against the tire was transmitted through the wheel,
knuckle arm, and ball joint to the control arm, which was successfully
braced by the strut bar, causing the end of the control outboard of the
strut bar to bend backward. (This force also possibly bent it upward at
the rear; the alternative is that the previous pot hole strike incident
had already bent the end of the control arm upward at its rear.) The
knuckle arm, wheel, wheel hub, and MacPherson strut assembly appear
undamaged. Complicating matters, there was and is a preexisting
condition of noise with rotation of that same (front left) wheel
bearing, apparently indicating a wheel bearing problem; this may have
been caused by the pot hole strike. Weeks before the collision, this
noise was rarely and barely detectable but became progressively more
noticeable over time; the problem remains (of course) after the accident
but is not substantially worse than it was just before it.
About the apparently undamaged parts, I invite and request any
suggestions about concealed damage which might have been done and that I
should specifically inspect for. The same goes for any damage that may
be invisible but that, in the spirit of conservative engineering, I
should assume occurred.
Many thanks in advance to all who will contribute. Keep those Toyotas
rolling!
"Stephen Bendzick" <stephenb@catholicexchange.com> wrote in message
news:444BB865.363DFC0E@catholicexchange.com...[color=blue]
> Hello!
> this post *
> 2. front left wheel bearing noise --pot hole strike-related?[/color]
Front wheel bearings are relatively easy to replace.
[color=blue]
> 4b. vibration at speed: driveshaft imbalance? --pending thru winter[/color]
Driveshafts generally do not go out of balance unless they are damaged. If
the vibration developed over time, check wheel/tire balance; check for
broken belts or unusual tread wear in the tire; and make sure the u-joints
are not binding. If you decide to unbolt the driveshaft, use different
colored paint to mark bolts, nuts, washers, and holes in the companion
flanges so that they all go back in the same combination to avoid causing
other balance problems.
[color=blue]
Try Chevron Techron or Toyota fuel injector cleaner and see if the problem
clears up. Sounds like a cold enrichment problem or a vacuum leak.[color=blue]
> way.[/color]
For the most part, ball joints on Toyotas are pretty durable, even when they
have not been routinely lubed.
The new part from Dallas Toyota sounds like a good deal.
If you decide to go with a used part, take a look at the boot for the ball
joint to see if it looks like it has been greased periodically and is not
dry. Also, take a look at the bushings on the control arm to make sure they
are not deformed.
[color=blue]
> else?[/color]
Not that I am aware of.
[color=blue]
> rolling!
> Stephen
>[/color]
Keep an eye on the rack where the rack end attaches to make sure no leaks
develop. Also, check the tire that hit the pothole for a broken belt or
blisters.
Sorry, I thought I had sent this on Wednesday, but it was still in my
"Drafts". Due to the complications of life, I still haven't done
anything new on the car, so this is still current. I will post again
when I do get something done (or when I see a reply here).
Ray O wrote:[color=blue]
> news:444BB865.363DFC0E@catholicexchange.com...[color=green]
> > Hello!
> > this post *
>[color=green]
> other balance problems.[/color]
I first noticed this vibration after a shop dropped the rear axle to
install a new exhaust. I'm thinking maybe they disconnected the drive
shaft (propeller shaft) and didn't put it back the same way.
Unfortunately, that was years ago; the car spent a year (ending about a
year ago) in semi-storage (wasn't registered and drove about 10 miles
all year, mostly from the street to the driveway and back), when I
couldn't afford to operate a car. I'm not positive the vibration wasn't
there before the exhaust work, but I don't think so. The vibration was
never too bad, so I just put up with it, because I was too poor to do
anything about it. Now I'm earning a good regular paycheck, so I'm
finally addressing all these issues that I have always wanted to
address. There's also some gummy residue on the drive shaft, and I was
going to clean the shaft before doing anything else. I'm also going to
have all four wheels balanced soon (after I fix the front suspension).
I have looked at the drive shaft U-joints, and they all seemed to have
good bearings (no play) that move smoothly, but I could look more
closely and systematically, when I get to this issue in detail.
You imply an interesting point, that just switching the bolts around
could change the balance. Somehow, I can see the mechanics at that shop
considering such attention to details unnecessary, so (in my mind) that
is a definite possibility. If the bolts were switched around, and/or
the companion flange alignment at the differential was shifted, is there
a way I could figure out the right configuration so I could put it back?
[color=blue][color=green]
> > 5. valve stem seals & tailpipe smoke @ warm-up --pending thru winter[/color][/color]
Something I read yesterday in an (old--from March) thread on this n.g.
suggested that burning oil could destroy the catalytic converter. If
that's the case, this will be aggressively moved up in priority. I have
changed the spark plugs twice (in the 32,000 miles I have had the car),
and they all had oil on them each time, so I know there is oil in the
cylinders. I presume it's coming past the 19-year-old valve stem
seals. I know how to replace those (the less invasive way), but I'd
been contemplating pulling the head so that I can inspect inside, fix
any valve problems, remove built-up deposits, replace the seeping head
gasket, and do the valve stem seal job more easily. Now, I'm thinking
I'd better just replace the seals from the top, and pull the head a few
years later when doing more restoration on the car.
> clears up. Sounds like a cold enrichment problem or a vacuum leak.[/color]
It's carbureted, but the vacuum leak suggestion is helpful; it's one of
the guesses I had considered. Could a carburetor in need of cleaning or
rebuild cause it to run rich when cold? (There's a lot more detail to
this problem, but we'll tackle that later.)
Last fall, I used Chevron-Texaco gasoline with Techron (went out of my
way to the one Texaco station that has it) for about 6 fill-ups in a
row, then intermittently about every second or third fill up for a
couple months more. It did improve power and smoothness when the engine
was warm, as well as fuel economy, which makes me think it was reducing
carbon deposits (which is what I was using it for, at Hachiroku's advice
[to someone else]). It didn't make much difference in the start-up
behavior, so I'm more inclined to suspect a cold start mechanism or
something due to thermal expansion. Like I said, there's a lot more
detail, and I have evidence that may point to a (minor) valve problem,
but I'd rather not troubleshoot too many problems at the same time, so
I'll get back to this after the control arm and wheel bearing are fixed.
Meanwhile, yesterday I did a three-hour push-the-accuracy-to-the-max
tape measure toe-in alignment adjustment, and I think I achieved an
inward toe of between 1/32 and 1/16 inch, measured as the difference in
the inside spans between the fronts and rears of the rims of the
wheels. (I assume that's where you're supposed to measure toe-in,
right?) Previously, it was about 3/8" inward toe, and I saw first hand
the "radical" change in steering handling that a manual told me toe-in
can cause--the Toyota turned like a big soft-suspension Cadillac. Now,
the car handles like it used to (which pleases me very much); the
steering is very responsive!
> > way.[/color]
> have not been routinely lubed.[/color]
Like my old one? :) (Guilty as charged.) I haven't noticed any signs
of wear, but for years (and about 20,000 miles) I didn't know how to
lubricate the ball joints, so . . . well, I'm making myself look bad
now, so I'll shut up. Anyway, now I lube them on schedule.
[color=blue]
> The new part from Dallas Toyota sounds like a good deal.[/color]
I think that settles it. I'll order ASAP.
[color=blue]
> are not deformed.
>[color=green]
> > else?[/color]
>[color=green]
> > rolling!
> > Stephen
> >[/color]
> blisters.[/color]
That same tire is the one that hit the other vehicle in the accident, so
I inspected it thoroughly, including rolling it down the driveway to
look for irregularities (radial asymmetries) in the rim or the tire, on
both sides. The tire looks good. (The trim ring, on the other hand, is
toast--somehow, in the accident, this wheel ran over its own trim ring!
The ring couldn't have rolled ahead; the car only continued about 2 to 3
feet from the point of collision. The ring must have somehow gotten
flipped out in front of the tire. When I got out of the car, the wheel
was squarely on top and in the middle of the trim ring!)
[color=blue]
> Ray O
> (correct punctuation to reply)[/color]
Thanks again, Ray! I'll post again once more work gets done.
news:4455670A.F3E9F906@catholicexchange.com...[color=blue]
> Ray O wrote:[color=green]
>> news:444BB865.363DFC0E@catholicexchange.com...[color=darkred]
>> > Hello!
>> > but
>> > this
>> > a
>> > this post *
>>[color=darkred]
>> If
>> u-joints
> shaft (propeller shaft) and didn't put it back the same way.[/color]
It is possible that the shop replaced the drive shaft out of phase. If the
shop had marked the companion flanges before removing the driveshaft then
they can avoid putting it back out of phase.
[color=blue]
> going to clean the shaft before doing anything else.[/color]
If the residue is on the driveshaft in big globs, then that can cause an out
of balance condition. If the driveshaft is just sticky then it is unlikely
to be the cause.
I'm also going to
[color=blue]
> a way I could figure out the right configuration so I could put it back?[/color]
If you want to try it yourself, mark the companion flanges and bolts so that
in the worst case, it goes back together the way it is now and best case,
the problem is solved.
[color=blue]
>[color=green][color=darkred]
>> problem
>[/color]
Yes.
[color=blue]
> I'll get back to this after the control arm and wheel bearing are fixed.[/color]
Check to make sure the choke is setting during cold starts.
[color=blue]
>[/color]
