Camry 2000 Vent Mode - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2006, 04:47 PM   #1 (permalink)
Cougar
Guest
Posts: n/a
View Cougar's Photo Gallery
I have a 2000 camry, 70K miles.
With AC or heater ON, I get air from vents on feet, defrost, and front
vents on the side. No air blows from the front vents in the middle.
It does not matter which option I choose on the vent mode switch (Face,
Face&Feet, Feet, Feet&Defrost, Defrost).
I opened the dash and got the mode switch out. Checked its continuity
as per Chilton's manual, and it is fine.
Does anybody know the continuity tests besides whats already in
Chilton's manual?
What else could go wrong that causes this problem?
I have opened most of the dash, but not the top dash. In order to
reach the ducts, do I need to open the dash completely?
Chilton's manual does not provide detailed information on reaching the
ducts. Is there a website for this?
Anybody experienced this problem?
Thanks for helping me out.
Old 04-24-2006, 05:08 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Camry 2000 Vent Mode
"Cougar" <akbar_aman@hotmail.com> wrote in message
news:1145915248.049471.312900@u72g2000cwu.googlegroups.com...[color=blue]
> Chilton's manual?
>[/color]
Assuming that:
1) the Chilton's manual is correct and you have properly checked continuity
and voltage at the switch
2) there is no manual shutoff for the air coming out of the center vents
3) or if there is a manual cutoff for the air coming out of the center
vents and you have the cutoff open,
Then, the next thing to check is the actuator for the dampers. The
actuator(s) are usually under the dash right next to the center console.
Moving the mode switch from feet to face, defog, etc. should make the
actuator move, which is attached to the damper.
Ray O
Old 04-24-2006, 10:10 PM   #3 (permalink)
andynewhouse@yahoo.com
Guest
Posts: n/a
View andynewhouse@yahoo.com's Photo Gallery
I have a 98 Camry, and I seem to remember reading something strange
about the middle vents in the owner's manual. Maybe they're only on
when air is set to "recirculate" or only "fresh/nonrecirculate", or
only above or below a certain temperature... I know the symptoms you're
talking about, but I obviously don't remember exactly what to do if you
really need air from the middle vents. Have you already looked in your
owner's manual?
Sorry I can't help more,
Andy
Old 04-26-2006, 08:12 AM   #4 (permalink)
Cougar
Guest
Posts: n/a
One more thing: With the vent mode switch disconnected (the dash is
completely dismantled), I connected the AC switch and the fan switch,
then I started the fan, and the air is still blowing on feet, deforst,
and front side vents - no air from the front middle vents.
Old 04-26-2006, 03:23 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:1146057174.707516.108140@i39g2000cwa.googlegroups.com...[color=blue]
>[/color]
A damper is not in the correct position.
Ray O
Old 04-27-2006, 01:33 PM   #6 (permalink)
Cougar
Guest
Posts: n/a
Ray,
Thanks for all the good advice.
Do I need to remove the fan assembly (blower) under the dash on the
passenger side to get to the damper?
Old 04-27-2006, 01:45 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:1146162805.452961.109300@g10g2000cwb.googlegroups.com...[color=blue]
> Ray,
>[/color]
I don't know for sure, but I doubt it. If you look around under the dash
while someone changes mode (vent, heat, bi-level, defog, you should see
cables moving levers. The levers are attached to the dampers inside the
ductwork.
Also, I believe that the center vents have on-off wheels next to the vents.
Have you tried to see if they are open?
Ray O
Old 04-27-2006, 10:51 PM   #8 (permalink)
Cougar
Guest
Posts: n/a
There are no on-off wheels for the center vents.
I plan to take out the fan motor assembly and look for leaves and also
try to locate the damper under the dash.
Old 04-27-2006, 10:54 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
news:1146196313.100828.279720@u72g2000cwu.googlegroups.com...[color=blue]
>[/color]
If there were enough leaves behind the fan motor to block air flow to the
center vents, it would probably stop flow to all of the vents and smell
pretty bad.
Concentrate your efforts on the damper.
Ray O
Old 04-29-2006, 07:50 PM   #10 (permalink)
Cougar
Guest
Posts: n/a
Thank you for helping me out Ray.
Even after removing the blower motor (fan) and the blower unit case, I
am unable to find the damper. I am reluctant to remove the upper dash.
I read on an online manual
[url]http://oregonstate.edu/~tongt/camry/99/index.html[/url] that the inlet damper
control cable controls the vent modes. However, I am unable to find
this cable. The central console, glove box, and lower dash is
completely disassembled.
I noticed that the continuity checks on the vent mode switch do not
meet the results specified in the Chilton's manual. I do not know if
Chliton's manual is incorrect or the vent mode switch is gone bad. In
order to see if Chilton's manual is correct, I am thinking to short the
pins using an electrical wire (as per Chilton's manual) on the cable
harness that connects to the vent mode switch. Could this cause any
damage to the electrical wiring of the car?
I just do not want to buy the vent mode switch unless I am sure if IT
IS THE CAUSE.
Old 04-30-2006, 01:22 AM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:1146358220.795495.137030@i40g2000cwc.googlegroups.com...[color=blue]
> IS THE CAUSE.[/color]
You can go to [url]http://techinfo.toyota.com/[/url] and pay for daily access to the
factory repair manuals. I believe the fee is $10 U.S. per day.
Shorting the pins on the harness that connects to the vent mode switch
should not cause a problem if it is just switching 12 volts. If it is less
than 12 volts then the switch is electronic and I wouldn't short it.
As far as finding the dampers that control air flow to various vents, listen
under the dash while you move the switch to various positions like defrost,
heat, vent, etc. You can hear better if the fan is on the lowest speed
setting, and you may be able to hear the dampers moving.
Good luck!
Ray O
Old 05-01-2006, 07:11 AM   #12 (permalink)
Cougar
Guest
Posts: n/a
Problem Resolved.
It was not the air outlet servo motor, but the plastic piece it
rotates. It was stuck. I just tapped it. It is working fine now.
To reach it, one needs to remove the lower dash panel on driver side,
plus the steering column cover.
I was lucky, that I do not have to take it out. So I just removed the
lower dash panel on the driver side.
It was a great experience.
Thank you Ray for helping me out.
Old 05-01-2006, 03:46 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
news:1146485518.862678.77650@i40g2000cwc.googlegroups.com...[color=blue]
> Problem Resolved.
>[/color]
You're welcome, although it sound like you did most of the work, diagnosis,
and repair yourself. Kudos for taking it on!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
2000 Camry Maintenance Diy Tips cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-26-2011 11:04 PM
Underdrive Pulley system for 5sfe (2000 camry) cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 31 12-07-2004 11:35 AM
need advice: what should my next mod be? 2000 camry cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-16-2004 10:05 PM
Camry 2000 Hood Latch mkrishna95050 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-11-2004 07:05 PM
92-96 Camry LE HVAC mode (question) 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-02-2004 02:44 AM
