I recently sprung a bad water leak, from the water pump i think, but
didn't catch it in time while coming home up the mountain, and she got
very hot and I'm told I've blown the head gasket.
I was also told how much it would cost for the mechanic to do it so I
thought I'd have a crack at it myself. Got myself a gasket kit and
started dissambling today.
Didn't get too far though. Everything was going fine until I got to
trying to take the cam gear off the cam shaft.
It is on TIGHT!! It broke my small ratchet, and just does seem to want
to give.
It doesn't mention anything special in the workshop manual, so I
thought I'd check here to see if there are any tricks I should be aware
of. The thread on the cam shaft isn't left handed is it?
What the manual does say is to "Place a lock bar through the camshaft
gear, loosen then remove the retaining bolt and remove the camshaft
gear"
Regarding the lock bar, Is a screw driver ok for this job? Is there a
suggested position for this?
Thats my two main questions for now, what can suffice as a lock bar,
and what is the trick for getting the cam gear off. If it is just
stuck, is it safe to use WD40 on this?
<cousn@pnc.com.au> wrote in message
news:1145957074.590343.230920@u72g2000cwu.googlegroups.com...[color=blue]
> Hi all,
> to give.
> of. The thread on the cam shaft isn't left handed is it?[/color]
I'm not positive, but I doubt it.
[color=blue]
> gear"
> suggested position for this?[/color]
It depends on whether the screwdriver's shank is strong enough to resist the
force of the wrench.
[color=blue]
> thanks for any help,
> Adam
>[/color]
Ray O wrote:[color=blue]
> news:1145957074.590343.230920@u72g2000cwu.googlegroups.com...[/color]
SNIP
[color=blue][color=green]
> > to give.
>[color=green]
> > gear"
>[color=green]
> > Adam
> >[/color]
> Rather than WD-40, try penetrating oil.
> Ray O
> (correct punctuation to reply)[/color]
Thanks for your help Ray. I got myself some penetrating oil and a good
quality ring spanner.
Gave a small squirt of penetrating oil, used a socket as a lock bar
then put on the ring spanner and gave a few sharp blows with a hammer,
and off she came.
news:1146120257.953051.108450@j33g2000cwa.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
> SNIP
>[color=green][color=darkred]
>> > to give.
>>[color=darkred]
>> > gear"
>> the
>>[color=darkred]
>> > Adam
>> >[/color]
>> Ray O
> and off she came.
> Cheers,
> Adam
>[/color]
The proper tools for the job certainly makes things go more easily!
