"GT-two" <theshipp@gmail.com> wrote in message
news:1145957435.862226.212020@i39g2000cwa.googlegroups.com...
Difference between the second and third gen blocks....
3rd has a different oil filter location IIRC The 2nd gen one crams in
between the turbo and alternator but it is still perfectly servicable with
the right tools. I think the oil->water heat exchanger is different on the
3rd gen too.
3rd gen *some* later blocks had thicker walls to the cyls. If you were
pushing BIG power (400+ fly hp) I'd try to find one of the thick walled
blocks but you can only do this by x-ray testing and you're only gonna do
that if you have a good budget and a few blocks. Below 400hp (some say more)
its not worth bothering. IIRC therees a few pushing 500+ on 'thin' walled
blocks.
3rd oil and water ways are different but 2nd gen blocks can fit 3rd gen
heads no problem (look at the differences in the head gaskets between the
st205 and st185). Im not 100% about 2nd gen heads on 3rd gen blocks but its
not something ive seen flagged as an issue in many many sessions of trawling
the archives.
3rd gen sump is slightly different IIRC but nothing to shout about, both are
baffled and perfectly capable.
AFAIK everything else is identical.
Cant help you with the hose info, never tried a swap.
Harness - the block wont change it as the only sensors in the block are the
knock sensor (im 99% certain the sensor is the same on both) and maybe the
oil level warning light that always goes wrong anyway and most people pull
out as they check their levels regularly.
Get over to [url]www.gt4oc.net[/url] and ask on there to be sure (you can register for
a free 60 day trial, then its £20 per year) but prepare to be gently
ridiculed for putting the 3sgte in a front wheel drive car :-) Dont take
anything personally, we just love our 4wd, and they'll be fine. I'm
'coyoteboy' on there too. Theres some commotions going on there at the
moment which means some of the uber-gurus have temporarily left (arguments
between staff and members which is all being sorted as we speak) but there
should be enough left to answer pretty much any 3sgte question you could
ever ask. Cars from stock power to >500hp with all combinations of
head/block/turbo you could think of lol.
J
