4K-C Will Not Idle - Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2006, 09:36 AM   #1 (permalink)
Monkeyboy
Guest
Posts: n/a
View Monkeyboy's Photo Gallery
Hello Everybody.
I would really appreciate any insight on a problem I have. I seem to
have lost my idle.
Car: 1982 Starlet KP61.
Engine: 4K-C (California) with Aisan 2-Barrel Carburetor. Idled "OK"
with original carb.
The car was running only OK, so I thought a reman carb would be a good
idea. Reman carb would not idle. Frustrated, I put the old carb back
on. Old carb will not idle. So I started all over.
1) I adjusted the mixture screw by the book
2) The idle speed screw has no effect until it is turned up to the
point where it bypasses the idle circuit.
3) The car starts, revs, and runs just fine - it just won't idle.
I've checked and rechecked the vacuum hose routing and it's all there.
What else would cause this problem? I'm stumped. I'm hoping for the
"That happened to me and I just..." answer.
Any suggestions are greatly appreciated.
Old 04-29-2006, 01:29 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 4K-C Will Not Idle - Help!
"Monkeyboy" <glazedape@yahoo.com> wrote in message
news:2006042907363867742-glazedape@yahoocom...[color=blue]
> Hello Everybody.
> I would really appreciate any insight on a problem I have. I seem to have
> lost my idle.
> Engine: 4K-C (California) with Aisan 2-Barrel Carburetor. Idled "OK" with
> original carb.
> idea. Reman carb would not idle. Frustrated, I put the old carb back on.
> Old carb will not idle. So I started all over.[/color]
Remeber the adage, "if it ain't broke, don't fix it." ;-)
[color=blue]
> 2) The idle speed screw has no effect until it is turned up to the point
> What else would cause this problem? I'm stumped. I'm hoping for the "That
>[/color]
When you say that it won't idle, I'm assuming you mean that the engine dies.
If so, check manifold vacuum to make sure you do not have a vacuum leak.
Also, for the vacuum hose routing, some vacuum switching valves have an "in"
and "out" so make sure the hoses are not switched.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Idle drops/engine bogs in gear (auto) tsuave Celica Forum 2 04-17-2006 02:53 PM
99 4-cyl idle air valve removal sixto Camry & Solara Lounge 3 02-18-2006 01:16 PM
cold idle rpm erquan Camry & Solara Lounge 4 01-29-2006 01:06 PM
Low Idle when cold and when AC is on Tom Simon Hardcore Tech and Competition 3 04-02-2005 03:04 AM
No Idle after motor rebuild wrenchdad MR2 Forum 0 01-09-2005 08:19 AM
