1993 previa rear noise left side..help :) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2006, 11:41 AM   #1 (permalink)
diamondroad
Guest
Posts: n/a
View diamondroad's Photo Gallery
I have a 1993 Previa that is making a grinding ( rumbling ) noise when
I take a left turn. the noise is coming from the right rear end.I was
just wondering if it could be bearings or lack of grease in the
bearings??. The van has 140,000 original kilometers.
Any help would be appreciated.
Thanks Kevin R
Old 04-30-2006, 01:48 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1993 previa rear noise left side..help :)
"diamondroad" <diamondroadmusic@hotmail.com> wrote in message
news:1146415284.356851.114670@j73g2000cwa.googlegroups.com...[color=blue]
> Thanks Kevin R
>[/color]
Your subject lists rear noise from the left side and your post says that the
noise is coming from the right.
If the noise is coming from the left, it is probably not wheel bearings. If
the noise is coming from the right when making a left turn, the noise may be
wheel bearings. Wheel bearings generally make noise whether the vehicle is
going straight or turning, with the noise changing in pitch when turning,
getting louder from the side opposite the direction of turn. In other
words, when making a left turn, a bad right wheel bearing will get louder or
higher pitched.
Other possibilities are rear brakes, axle, and differential bearings.
If you have rear disc brakes, make sure the backing plate is not rubbing
against the rotor and check the pads for wear. If you have drum brakes,
check them for proper adjustment, shoe wear, and brake dust accumulation.
If you have never had the differential fluid changed, it wouldn't hurt to do
so and inspect the drained fluid for metal particles. Inspecting
differential and axle bearings requires more skill and tools than the
average owner.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Wind noise around rear passenger door Bill_H2003 Camry & Solara Lounge 1 05-16-2004 01:11 PM
2004 Camry 4cyl A/T Booming Noise in Rear LPB 5th & 6th Generation (2002-2006 & 2007-2011) 2 04-22-2004 05:18 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
