1993 celica blowing fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2006, 04:15 PM   #1 (permalink)
labina1
Guest
Posts: n/a
View labina1's Photo Gallery
My daughter has a 93 celica gt automatic. Everytime AC is turned on
blows fuse. Afterwards no AC, no power window and no rpms but car runs
fine. Any suggestions?
Old 04-30-2006, 05:30 PM   #2 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
Re: 1993 celica blowing fuse
"labina1" <gussie1966@yahoo.com> wrote in message
news:1146431758.847268.313860@g10g2000cwb.googlegroups.com...[color=blue]
> blows fuse. Any suggestions?[/color]
I'd guess that the AC compressor clutch circuit is the culprit. There's a
relay that switches the main current. Buy a bag of fuses and disconnect the
clutch (trace the wire in the engine bay). See if firing the clutch relay
still blows the fuse.
Side issue: If the AC is not pressurized, be aware this car is R12 based.
Its cheaper in the long run to get it converted to R143a than find someone
who can supply and install R12. If the AC is still partially pressurized,
get a can of durakool R12 compatible and see if it holds up.
SD
Old 04-30-2006, 05:57 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
>[/color]
If the fuses blows immediately, then there is a direct short to ground
somewhere in the affected circuit. You will need a wiring diagram and a
multi-meter to diagnose the problem. Start by checking any aftermarket
accessories or parts than have been tapped into the circuit, like remote
starters, security systems, lights, and audio systems. Then check the power
window master switch and circuit, then the AC circuit.
If it takes a while before the fuse blows, then there is high load
somewhere. You have to determine which item makes the fuse blow, i.e.,
turning on the AC or using a power window and check the operation of the
load on the circuit.
Ray O
Old 05-01-2006, 12:19 PM   #4 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
> Side issue: If the AC is not pressurized, be aware this car is R12 based.[color=blue]
> SD[/color]
You can, if you search enough, find someone who can fit drop-in R12
replacement gas (R49 and a couple of others) for fractionally more than a
modern car refil.
J
BB code is Off
Smilies are Off
[IMG] code is Off
Scion FUSE: An Evolution [Video On Demand Documentary]! ScionVIP Scion Forum 0 04-12-2006 02:34 PM
1992 Celica blowing white smoke $modelman$ Celica Forum 1 05-23-2005 02:11 PM
82 celica where's a/c fuse circuit breaker anderbud Celica Forum 0 08-14-2003 03:00 AM
82 Celica A/C switch Fuse DaveG Celica Forum 0 08-12-2003 11:08 PM
