What are the anticipated and unanticipated sources of oil leaking onto
garage floors from engines etc.?
How much is normal? At what point should one be concerned -
especially with older cars? Clear oil would be a giveaway IMHO.
Are the 2006 and newer models expected to perform better over a
lifetime than cars made say 10 or 20 years ago? In other words has
there been any significant change in technology - or/and is there a
real difference between brands?
"joe" <nospam@invalid.com> wrote in message
news:qhrc52dk5tkllm7791ggpljl7auvdhc6l9@4ax.com...[color=blue]
> garage floors from engines etc.?[/color]
The parts of the drivetrain that contain fluids are the potential sources of
stains on the garage floor. These potential sources of leaks are the
transmission, power steering system, cooling system, and the engine
lubrication system. Oil can leak from the lubrication system in a number of
places, including the oil pan, oil filter, valve cover gaskets, heads, oil
pressure senders, diswtributor shafts, front and rear seals, etc.
[color=blue]
> especially with older cars? Clear oil would be a giveaway IMHO.[/color]
If oil is leaking on to the floor, then I would be concerned and check the
source of the leak. If the oil is leaving a damp spot on the side of the
block, valve cover, etc., then I'd keep an eye on it but not worry too much.[color=blue]
> regards,
> joe[/color]
On Mon, 1 May 2006 16:11:48 -0500, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>news:qhrc52dk5tkllm7791ggpljl7auvdhc6l9@4ax.com...[color=green]
>[color=green]
>block, valve cover, etc., then I'd keep an eye on it but not worry too much.[color=green]
>> regards,
>> joe[/color]
>Yes, yes, and it depends on the brands.[/color]
Thanks Ray for another thoughtful answer.
Almost hate to ask but which would be known as better or worse brands?
What did they change to get better? <Grin>
j
news:fjuc52lrcbushhr2gopjcmfl1i3ske89rd@4ax.com...[color=blue]
>[color=green]
>>news:qhrc52dk5tkllm7791ggpljl7auvdhc6l9@4ax.com...[color=darkred]
>>of
>>of
>>[color=darkred]
>>much.[color=darkred]
>>> regards,
>>> joe[/color]
> j[/color]
Since you are asking in a Toyota ng, the majority of regular posters here
will say that Toyota is the best brand. One will prefer Honda or Chrysler,
one will prefer Ford, and one will say that the quality of all cars are the
same.
You can study Consumer Reports or J.D. Power surveys to see short and long
term reliability, and you can ask an independent mechanic what vehicle he
would buy if he was in the market, based on what he fixes. I would use the
information a little differently than most people. In addition to checking
out which automakers have the most models that are highly recommended or
with the fewest number of problems, I'd also check out which automakers have
the most models that are not recommended or have a lot of problems. For
example, if Mega Auto's Green Apple model was highly rated but their Golden
Delicious model was problematic, then I'd worry about the quality of the
products from Mega Auto.
All automakers make improvements to their products over time, so I'd expect
all of them to perform better over their lifetime than 10 or 20 years ago.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:291ea$4456799a$44a4a10d$5008@msgid.meganewsservers.com...[color=blue]
> of stains on the garage floor. These potential sources of leaks are the
> of places, including the oil pan, oil filter, valve cover gaskets, heads,
> oil pressure senders, diswtributor shafts, front and rear seals, etc.
>[/color]
news:c5e24$44567e36$44a4a10d$5185@msgid.meganewsservers.com...[color=blue]
> news:fjuc52lrcbushhr2gopjcmfl1i3ske89rd@4ax.com...[color=green]
>>[color=darkred]
>>>of
>>>of
>>>oil
>>>the
>>>much.
>>>> regards,
>>>> joe
>> j[/color]
> Chrysler, one will prefer Ford, and one will say that the quality of all
> cars are the same.
>[/color]
Whoa, Ray. I think the question was about the quality of oil, not the
quality of cars in general. I could be wrong, but I think that his concern
was if oil was less prone to leakage today than in years past.
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:Y7idnUcOnfjPisXZnZ2dnUVZ_sKdnZ2d@ez2.net...[color=blue]
> news:291ea$4456799a$44a4a10d$5008@msgid.meganewsservers.com...[color=green]
>>[/color]
> Don't forget the differential(s).
>[/color]
good call - plus, transfer cases if so equipped, brake system, transmission
and/or power steering coolers, washer system, etc.
news:W_idnQMjWYWehcXZRVn-jw@ez2.net...[color=blue]
> <snipped>[/color]
[color=blue][color=green][color=darkred]
>>>>> regards,
>>>>> joe
>>> j[/color]
>> cars are the same.
>>[/color]
>[/color]
I interpreted the question about cars because the question was "Are the 2006
and newer models expected to perform better over a lifetime than cars made
say 10 or 20 years ago? In other words has there been any significant
change in technology - or/and is there a real difference between brands?"
I provided a response to those questions, and the poster submitted the
question about better or worse brands, which I took to mean auto brands, not
oil brands.
On Tue, 2 May 2006 19:35:47 -0700, "Jeff Strickland" <crwlr@yahoo.com>
wrote:
[color=blue]
>> regards,
>> joe[/color]
>You are asking about oil on the floor, but seem to associate this with the
>oil itself. Me thinks that oil on the floor is more a function of gaskets
>and seals than of the oil ...
>The question isn't if the oil has changed -- it has changed remarkably, but
>not in ways that keep it from leaking -- but if gaskets and seals have
>changed.
>[/color]
To most of us oil is just by weight period.
My concern are those engines that the engineers never finished
designing such as at least one by GM that requires ground up walnut
shells (from real nuts!) in the cooling water - "to prevent leakage of
water into the engine oil". Clearly a piss poor mechanical and gasket
design resulting in countless blown engines. GM transmission seals
may also require a 2k rebuild at an early age. Been there- done that.
I'm sure every joint or mating surface can or will leak sooner or
later under some circumstances. Rather than a long listing of those -
are there some - say the top five places that oil starts to leak when
the car matures? Are there patterns of these problems with certain
Toyota models?
joe
PS good to see GM car sales (April) down by about 11.5% today and
Toyota up by about 4.5% - they have earned that.
news:lv9g521pq9o6clo15ibd9nrh72gjrrq67d@4ax.com...
<snipped>
>>but
>>changed.
>>[/color]
> Toyota models?
> joe
> Toyota up by about 4.5% - they have earned that.[/color]
Our 97 Avalon has 110,000 miles, the area below the valve cover gasket is a
little oil stained but not dripping yet.
The FIPG on our '93 Previa started to get a little damp around 90,000 miles,
didn't start dripping.
Our '03 Sequoia with 36,000 miles and our '00 LS 400 with 80,000 miles are
bone dry.
news:lv9g521pq9o6clo15ibd9nrh72gjrrq67d@4ax.com...[color=blue]
> wrote:
>[color=green]
>>> regards,
>>> joe[/color]
>>but
>>changed.
>>[/color]
> design resulting in countless blown engines.[/color]
I am blissfully unaware of ANY corporate requirement of putting walnut
shells into anything. I do not deny that grandpa might have done such
things, or that I did them when needed. But this was not the corporate line.
GM transmission seals[color=blue]
> Toyota models?
> joe
Oh, NOW I get it, you're on a rant against GM. Sorry to jump in. I thought
you were wondering about oil spots on the floor.
On Wed, 3 May 2006 17:05:48 -0700, "Jeff Strickland" <crwlr@yahoo.com>
wrote:
[color=blue]
>news:lv9g521pq9o6clo15ibd9nrh72gjrrq67d@4ax.com...[color=green]
>> wrote:
>>[color=darkred]
>>>> regards,
>>>> joe
>>>but
>>>changed.
>>>[/color]
>[/color]
Grasshopper,
This is provided in pellet form at every Cadillac dealer.
The ingredient is as stated - as hard as it is to believe. This is
what one does when mating surfaces are not adequate and seals can not
do the job. Pick up the phone and call your local GM Cadillac dealer.
Failure to use 'pellets' will no doubt void any warranty.
j
[color=blue]
>GM transmission seals[color=green]
>> Toyota models?
>> joe
>[/color]
wrote:
[color=blue]
>> wrote:
>>[color=darkred]
>>>> regards,
>>>> joe
>>>but
>>>changed.
>>>[/color]
>[/color]
Grasshopper,
j
PS I believe I can get you a part number if the ***** dummy up on you.
[color=blue]
>> Toyota models?
>> joe
>[/color]
news:4oWdnRFttuLG2MTZnZ2dnUVZ_vGdnZ2d@ez2.net...[color=blue]
><snipped>[/color]
To most of us oil is just by weight period.[color=blue][color=green]
> line.
>[/color]
The first use of walnut shells in a mechanical device I heard of was in
aircraft engines because the shells effectively "blasted" the carbon off
while being consumed in the engine.
The next use I heard of was at BMW dealerships to remove carbon buildup on
valves.
Toyota used them for derivability problems in mid-1980's Tercels.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>news:4oWdnRFttuLG2MTZnZ2dnUVZ_vGdnZ2d@ez2.net...[color=green]
>><snipped>[/color]
> To most of us oil is just by weight period.[color=green][color=darkred]
>> line.
>>[/color]
>[/color]
Yes, I'm also familiar with this use Ray...the shells are (as you
say) hard and abrasive enough to clean the carbon and dirt off
both the compressor and the turbine blades while not damaging
them and then are burned up later...
[color=blue]
>valves.
>Toyota used them for derivability problems in mid-1980's Tercels.[/color]
