Re: 91 Celica, surging engine
"ADL" <adleigh@gmail.com> wrote in message
news:1d6dnX2Ni-SyWMvZRVn-vw@suscom-maine.net...[color=blue]
>I have a 1991 Celica GTS, 5SFE 5sp. I am fixing up. It has 287K, with
>about 110K on the motor.
> The engine races usually at about 1800 RPM when I start to move in first,
> and also while I am driving in any gear, but the RPM doesn't really shoot
> up to much, just the forward motion. When I take my foot off the gas it
> calms down. It's almost like an uncontrolable turbo boost, lurching the
> car. When it happens I hear what could be a vacuum noise. I can't seem to
> find any obvious vacuum leaks.
> Also, when I first start the car, the engine shoots up to 2,000 RPM, then
> back to 1000, if it's cold, it cycles like this a few time from +/-2,000
> to 1,000 then comes out of it and idles just below 1,000.
> Any suggestion on what component might cause this if there is a problem
> with vacuum somewhere?
> Thanks for the help
> -Andrew[/color]
A vacuum gauge will confirm the presence or absence of a vacuum leak.
Sometimes the hoses get hard and crack or the vacuum fittings get brittle
and crack. You can spray carb cleaner and see if engine rpm increases when
you spray in a certain area.
Another possibility is a crack in the intake tube between the air cleaner
and throttle body.
Ray O
