Strange rattle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2006, 10:07 AM   #1 (permalink)
RD
Guest
Posts: n/a
View RD's Photo Gallery
Strange rattle
98 Camry, 4 cyl, 180K
Almost like a vibration going over rough rode. New struts and strut mounts
did not clear it up. Sounds like its coming from A pillar and forward.
Strange anomalies: More pronounced with a passenger. Pretty much disappears
with a good weight in the trunk.
Suggestions?
RD
Old 05-02-2006, 12:20 PM   #2 (permalink)
Jason James
Guest
Posts: n/a
View Jason James's Photo Gallery
Re: Strange rattle
"RD" <dosvader2061@hotmail.com> wrote in message
news:e37sik$a3t$1@tribune.usask.ca...[color=blue]
> Strange anomalies: More pronounced with a passenger. Pretty much[/color]
disappears[color=blue]
> Suggestions?
> RD[/color]
If its a light rattle, its more likely to be a component of the suspension
which is not under a lot of load, such as the roll or sway-bar connections.
These are rubber shock-insulated small ball-joints IIRC. A proper inspection
shuld not be difficult in locating them as the fault.
If its a heavier sound, considering the struts have been replaced, I'd be
examining the lower-arm bushes, the lower ball-joint which supports the
lower end of the strut, and the upper rotaional mount of the strut.
Other culprits could be the brake-caliper slide-pins rattling (check caliper
for rigidity in its mounts). Loose brakes pads can rattle due to too little
residual line pressure in the brake's hydraulics (master cylinder) or a
warped disc upsetting the pads restposition,..or the wheel itself ie
bearing, hubcap etc
The rear weight effect tho, tends to point to the rollbar or the strut's
mounting hardware.
Jason
Old 05-02-2006, 02:50 PM   #3 (permalink)
Grump
Guest
Posts: n/a
View Grump's Photo Gallery
Re: Strange rattle
I have a 99 Camry that is in need of rear struts. I was just curious
what did you end up spending on the struts and mounts?
Old 05-02-2006, 03:17 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Strange rattle
"Jason James" <Cleveland@351.factory.4v> wrote in message
news:445794c8$1@news.comindico.com.au...[color=blue]
> news:e37sik$a3t$1@tribune.usask.ca...[color=green]
>> mounts
> disappears[color=green]
>> Suggestions?
>> RD[/color]
> connections.
> inspection
> caliper
> little
> bearing, hubcap etc
> mounting hardware.
> Jason
>[/color]
Unfortunately, rattles are difficult, if not impossible, to diagnose without
actually hearing them.
Aftermarket brake pads sometimes rattle.
If the noise is more pronounced with a passenger in the front seat and is
less pronounced with a load in the trunk, there is an obvious remedy...
Ray O
Old 05-02-2006, 03:40 PM   #5 (permalink)
RD
Guest
Posts: n/a
Re: Strange rattle
First of all I'm in Canada:
$84 x 2 - Munro struts 'coz the previous Toyota ones failed after only 30km
and only a one year warranty.
Labour - $50 / strut (private mechanic)
Typically, however, it usual works out to $200+ / corner.
As for Ray O suggestion, I like that one best!
"Grump" <grump_78@yahoo.com> wrote in message
news:1146599417.349033.323930@u72g2000cwu.googlegroups.com...[color=blue]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Rattle from passenger side coloradotaco 2nd Generation (2005+) 10 01-09-2008 09:41 PM
Rattle CLIFF RAV4 Forum 1 03-08-2006 09:10 PM
Rear suspension rattle? mmurray70 Camry & Solara Lounge 21 08-24-2005 12:05 PM
XB Dash/Speedometer Rattle not Radio rtrimyer xB Lounge 1 06-22-2005 11:24 PM
stopping my trunk rattle... Hamsterman Audio, Video, and Security - Tech 8 05-28-2005 09:47 AM
