Removing tape residue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2006, 11:55 AM   #1 (permalink)
---MIKE---
Guest
Posts: n/a
View ---MIKE---'s Photo Gallery
This winter I had a few driver side door freeze-ups when rain was
followed by a sudden freeze. In an effort to prevent this, I put duct
tape against the window and the door. When I removed the tape, there
was a white residue left on the door. What would be the best way to
remove this?
---MIKE---[color=blue][color=green]
>>In the White Mountains of New Hampshire
>> (44° 15' N - Elevation 1580')[/color][/color]
Old 05-02-2006, 01:52 PM   #2 (permalink)
zonie
Guest
Posts: n/a
View zonie's Photo Gallery
Re: Removing tape residue
I would try using some wd-40. It works very well at removing glue left by
stickers or tape. I would spray it on a cloth and rub it on the residue,
let it sit for a while and then rub it off. It also works really good at
getting off road tar, and will not damage yout paint. Scott
Old 05-02-2006, 03:19 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"zonie" <sjemoomaw@nospam> wrote in message
news:05af9164b9bf291aa6675a87faabbd9b@localhost.talkaboutautos.com...[color=blue]
>[/color]
Goof Off also works well.
To reduce the likelihood of freeze-up next winter, spray silicone spray on
the door gaskets and wipe with a paper towel.
Ray O
Old 05-02-2006, 07:19 PM   #4 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
WD40 removes adhesive. It ought not damage the paint, or the wax (but if
there was much wax, the tape should have trouble sticking in the first
place). I'd use WD40 on a small patch and see what happens.
"---MIKE---" <twinmountain@webtv.net> wrote in message
news:10935-44578EF8-632@storefull-3258.bay.webtv.net...
remove this?
Old 05-03-2006, 08:54 AM   #5 (permalink)
---MIKE---
Guest
Posts: n/a
Ray O said:
[color=blue]
> next winter, spray silicone spray on the
> towel.[/color]
The freeze up was internal. I could open the door but then it wouldn't
stay closed until the car warmed up. Sometimes IF it closed, I couldn't
open it from the inside. I thought that maybe the rain leaked in
between the door and the window. The duct tape didn't help and now I
have the white residue from the tape stuck on the door. I tried WD40
but it didn't touch the residue.
Old 05-03-2006, 10:56 AM   #6 (permalink)
CEM
Guest
Posts: n/a
View CEM's Photo Gallery
On Wed, 3 May 2006 09:54:14 -0400, [email]twinmountain@webtv.net[/email] (---MIKE---)
wrote:
[color=blue]
>Ray O said:
>[color=green]
>> towel.[/color]
> ---MIKE---[color=green][color=darkred]
> >> (44° 15' N - Elevation 1580')[/color][/color][/color]
Try paint remover. Then, you won't have to worry about the paint any
longer nor the residue <grin>.
Old 05-03-2006, 10:58 AM   #7 (permalink)
rob
Guest
Posts: n/a
View rob's Photo Gallery
On Tue, 2 May 2006 12:55:20 -0400, [email]twinmountain@webtv.net[/email] (---MIKE---)
wrote:
[color=blue]
>remove this?
I had this problem once but not on my car. I think I used rubbing
alcohol to get it off. I don't think it will damage your car paint
but try it on a small spot inside the door jam first to make sure.
Old 05-03-2006, 11:17 AM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:24542-4458B606-662@storefull-3253.bay.webtv.net...
Ray O said:
[color=blue]
> towel.[/color]
Try Goof-Off, lacquer thinner, mineral spirits, or brake cleaner to remove
the residue. It is normal for some moisture to get inside the door so make
sure that the drain holes at the bottom of the door are free from mud and
debris by poking a stiff wire through the holes. Spray some lithium grease
on the door moving part of the door latch so that the latch does not freeze
up. If you really want to go all out, get some Lock-Ease in an aerosol can
and use the snorkel that comes with the can to lube the lock cylinders and
then pull the exterior door handle and use the snorkel to spry the moving
parts of the door handle.
Ray O
Old 05-03-2006, 11:43 AM   #9 (permalink)
frank t.
Guest
Posts: n/a
View frank t.'s Photo Gallery
On Wed, 3 May 2006 11:17:39 -0500, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>Ray O said:
>[color=green]
>> towel.[/color]
>parts of the door handle.[/color]
I'd be very careful about brake cleaner. I heard years ago that will
take paint off a car. Regardless, try whatever in the door jamb
first just in case it does take the paint off or mar the paint finish.
Old 05-03-2006, 01:15 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
<frank t.> wrote in message
news:8anh525io5i3uas8d82va9niinl2955bbc@4ax.com...[color=blue]
>[color=green]
>>Ray O said:
>>[color=darkred]
>>> towel.[/color]
>>make
>>grease
>>freeze
>>can
> first just in case it does take the paint off or mar the paint finish.[/color]
If you use brake cleaner, spray it on and wipe it right off or spray it on a
rag and wipe. It will remove wax but it won't take the paint off if you
wipe it right off.
Also, bug and tar remover works well.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
What OE AM/FM CD players can I install in 94 Camry to replace stock AM/FM Tape playr? green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-22-2006 04:56 PM
Please check out --> I need a How-to on removing door handles... mystickid Camry & Solara Lounge 4 05-04-2005 04:47 PM
Replacing Factory In-Dash CD in 4Runner's double-DIN slot & keep Tape? ben_4runner Audio, Video, and Security - Tech 4 03-17-2005 11:55 AM
2002 Corolla tape deck in 2003 Echo louise Audio, Video, and Security - Tech 1 08-04-2004 11:07 PM
