Re: AC help for 2003 Corolla
On 2 May 2006 20:06:14 -0700, "Trog" <rhettjay@gmail.com> wrote:
[color=blue]
>Thanks qslim,
>Would using some place simple like Jiffy Lube be ok, or should I take
>this to the (expensive) dealer?[/color]
Unless under warranty I would take it to a good independent ac shop.
They should be able to tell you if it cools enough. Be aware, it can
take a bit before the ac gets the car really cold in the southwest on
a hot day. It won't be instantly if your car has been baking in the
hot sun all day. There should be a certain temp drop (difference
between outside air and air coming into car). I am not sure how much
that it but you can measure it yourself.
