Re: '98 Tacoma OBD Not responding
I had the same problem on my 1997 Toyota Corolla. Search the group for
"1997 OBD Corolla" and you'll find the thread.
Ray posted some very useful information on how to test the OBD-II port
using a multimeter. My problem was ended up being simple to fix. I
decided to trace the harness and as I took off the kick-panel under the
steering column, I found that one end of the harness that connected to
the OBD-II port was unplugged. I plugged it back in and the port
worked as expected. Since you have already checked the fuses, I would
start tracing the harness back from the port.
Cheers,
Nirav
