Toyota Corolla-94 brake light assembly removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2006, 11:31 AM   #1 (permalink)
SR
Guest
Posts: n/a
View SR's Photo Gallery
While trying to remove my Toyota Corolla-94 brake light assembly, I was
able to remove the two outside black screws as well as the gold colored
nut behind the trunk liner, but there are two black plastic clips or
anchor points keeping the tail light assembly from coming out. I am
not able to remove those two plstic mount. Can some body help me to
remoive this, so that I can replace my brake light? Thanks for
the help...
Old 05-04-2006, 11:50 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota Corolla-94 brake light assembly removal
"SR" <rath.saroj@gmail.com> wrote in message
news:1146756682.118120.295870@i40g2000cwc.googlegroups.com...[color=blue]
> the help...
>[/color]
Toyotas use 2 types of plastic clips.
If the clip has a small button in the center, gently poke the button inwards
with something like a retractable ball point pen with the point retracted,
then pull the clip out. To replace, pull the button out so that it
protrudes from the face of the clip, press the clip into the hole, and push
the button in so that it is flush with the face of the clip.
If the clip does not have a button in the center, the easiest way to remove
the clip is with a clip removal tool. If you do not have a clip removal
tool, you can use 2 putty knives on each side of the face of the clip and
pull it out. Auto parts stores sell clip removal tools, they generally look
like a screwdriver with a bent shank and a very wide blade that has a notch
in the blade.
Ray O
Old 05-04-2006, 02:30 PM   #3 (permalink)
someone@somewhere.org
Guest
Posts: n/a
View someone@somewhere.org's Photo Gallery
SR <rath.saroj@gmail.com> wrote:[color=blue]
> the help...[/color]
Assuming you are talking about the turn/stop/tail light cluster there are no
plastic clips. You've got all the bolts. Its just a matter of pulling
straight out very hard. There are two pins on the outside edge of the
light clusters. If you haven't had the light out in several years these
pins may be corroded to the metal clips and not want to brake free. Just
pull harder. :-)
Old 05-13-2006, 10:19 PM   #4 (permalink)
Ralph
Guest
Posts: n/a
View Ralph's Photo Gallery
Jack mumbles:
I think I just had the same problem.
Out of sight behind the tail light cluster are two rods which corrode. The
cluster slides along on these rods. See if you can spray some lubricant in
behind the cluster by prying on it a little from the edge closest to the
front of the car. It will help. Hanes doesn't show info on this assembly.
The rods go through a pair of plastic hoops which are bolted into the side
of the trunk. If you pry very hard (I used two pieces of wood like wedges),
the assembly can be forced off - but I snapped one of the rings. Maybe I can
fix if with shoe goo!
Perhaps I should grease these rods.
Good luck to you.
- Jack
BB code is Off
Smilies are Off
[IMG] code is Off
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 24 09-16-2011 06:07 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
ASAP A/C Evaporator removal 94 Toyota Camry??? 94_v6_camry 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-26-2004 04:54 PM
Corolla 91 brake light switch cronnos Archived Corolla threads 6 09-14-2004 12:54 PM
