Re: Low Brake Pedal-Corolla
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:B7SdnReDrv9Wq_zZnZ2dnUVZ_t-dnZ2d@ez2.net...[color=blue]
> "<snipped>[color=green]
>> Not all self-adjusting brakes are activated by stopping while going
>> backwards. Some are activated by using the parking brake.
>>[color=darkred]
>>> The brakes can easily wear while the self adjusters take a vacation, and
>>> the recovery action is to adjust them manually to get the pedal travel
>>> back in line. Certainly, the brakes can wear to the point they require
>>> replacement, but replacement isn't always required when the pedal travel
>>> is long.[/color]
>> You just made my point that the root cause of the low pedal is wear;
>> adjustment is the remedy. ;-)
>>[/color]
> That's what I said in the first place, you replied that replacement was in
> order.
>[/color]
We must be reading more into each other's posts than we actually post. ;-)
I re-checked my first reply to the OP, I said "The most common cause of long
brake pedal travel is worn brake linings." I didn't mention that
replacement was in order because I never assume that without seeing the
parts or knowing the actual lining thickness. If you take a look at my
posts, I rarely recommend replacing parts. I usually recommend checking
parts.
Ray O
