95 Avalon overheating problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2006, 10:22 AM   #1 (permalink)
resers@bellsouthgarbage.net
Guest
Posts: n/a
View resers@bellsouthgarbage.net's Photo Gallery
Cooling fan doesn't seem to be coming on and engine is overheating in
traffic. When Engine Coolant Temperature (ECT) switch #1 is
disconnected, the fans come on. It seems I need a new ECT #1. Anything
wrong with my analysis? Toyota wants nearly $100 for this switch which
is unbelievable. Any other reputable sources for this part at a more
reasonable price? Thanks.
Old 05-05-2006, 12:00 PM   #2 (permalink)
tom418
Guest
Posts: n/a
View tom418's Photo Gallery
Re: 95 Avalon overheating problem.
Per the Toyota Repair Manual (p. EG201):
No. 1 EGT switch is open at temps above 208F (98c) and closed below
190F(88c)
(similar for #2 ECT switch, but 93c/83c open/close temps)
"resers@bellsouthgarbage.net" <resers@bellsouth.net> wrote in message
news:1146838979.884572.31050@i39g2000cwa.googlegroups.com...[color=blue]
>[/color]
Old 05-05-2006, 02:28 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
>[/color]
There is a specific temperature at which the switch should open or close,
which Tom418 was kind enough to provide.
Rather than just unplugging the switch, check continuity with the engine
warmed up and cold. You should have continuity when the coolant is cold and
open circuit when the coolant is hot.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
01 avalon gauge problem covfd153 2nd Generation (2000-2004) 4 03-05-2010 08:32 AM
Thinking about buying a '95 Avalon next week!!! I Need Advice, ASAP reezytercel 1st Generation (1995-1999) 5 10-09-2006 11:59 PM
Help With One-time Knock Noise Upon Acceleration - 95 Avalon 95avalonguy 1st Generation (1995-1999) 4 05-18-2005 09:13 PM
95 Avalon Check Engine Light and Flashing OD Light teke175 1st Generation (1995-1999) 0 04-27-2005 11:17 AM
problem with gen2 engine( keeps overheating) heigo2 1st & 2nd Generation (1983–1986 & 1987-1991) 5 10-03-2003 10:20 PM
