Aux jack and 12 volt power jack on 2006 Rav4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2006, 11:15 AM   #1 (permalink)
barkkkusNS@NSyahoo.com
Guest
Posts: n/a
View barkkkusNS@NSyahoo.com's Photo Gallery
Greetings All!
Was wondering if anyone in the group was able to use these jacks at
the same time on their vehicle without getting lots of background
"hiss" in the playback.
Trying to power my portable XM receiver with any 12 volt jack while
using the aux jack for output through the factory speakers produces a
very noticeable "hiss" or "whine" that rises and falls in direct
relation to the rise and fall of the engine RPM.
No problem at all if I use the XM receiver on battery or use the FM
transmitter for output.
Thanks in advance for your thoughts.
-Barry
Old 05-05-2006, 09:33 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Aux jack and 12 volt power jack on 2006 Rav4
On Fri, 05 May 2006 11:15:10 -0400, barkkkusNS wrote:
[color=blue]
> Greetings All!
> -Barry[/color]
Hmmm... I would try grounding it.
This could be risky...I have a spare Roady2 if you ground it wrong!
In all honesty, you want to ground the 'case' of the XM radio to the car
head unit.
Since the case is plastic, this will be tough.
Look on the adapter and see if the outside connection of the power
connector is groun (or '-'). It should be. You couls run a wire from where
to the radio.
I have a spare Roady2 if I'm wrong...
Mine has a built-in transmitter...I just use that.
BB code is Off
Smilies are Off
[IMG] code is Off
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 11:03 PM
