help with mx73 starting problems? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2006, 03:39 PM   #1 (permalink)
G Evans
Guest
Posts: n/a
View G Evans's Photo Gallery
88 cressida, this is the problem wouldn't start last fall, turns over but no
fire up, towed to garage, new rotor cap and wire, works fine till 2 weeks
ago, same thing turns over no fireup, tow to garage, they play around and
finally tell me needs new igniter/coil, they install a used one works for
two start ups then nothing, wait for tow truck, tow truck driver and I try
to start it and it starts, drive for 2 days then guess what no fire up,
waited 20 minutes then fired up went straight to garage, he says it may have
been a loose wire and it should be fine now, goes 5 days and same thing
mechanic visits car he can't start it, he tows it in to his shop, he tries
it at the shop and it starts. says he can't fix it now that it starts, I
take it home it is in my garage, I am going over the ignition wires with a
fine tooth comb right now but would appreciate any one who can tell me what
is going on. I will look at ecu for loose or damaged wires as soon as
daughter gets home with glove box key.
Thanks, gerry
Old 05-06-2006, 11:23 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: help with mx73 starting problems?
"G Evans" <gereva@interbaun.com> wrote in message
news:125purblkse9m80@corp.supernews.com...[color=blue]
> no fire up, towed to garage, new rotor cap and wire, works fine till 2
> weeks ago, same thing turns over no fireup, tow to garage, they play
> around and finally tell me needs new igniter/coil, they install a used one
> works for two start ups then nothing, wait for tow truck, tow truck driver
> and I try to start it and it starts, drive for 2 days then guess what no
> fire up, waited 20 minutes then fired up went straight to garage, he says
> it may have been a loose wire and it should be fine now, goes 5 days and
> same thing mechanic visits car he can't start it, he tows it in to his
> shop, he tries it at the shop and it starts. says he can't fix it now that
> it starts, I take it home it is in my garage, I am going over the ignition
> wires with a fine tooth comb right now but would appreciate any one who
> can tell me what is going on. I will look at ecu for loose or damaged
> wires as soon as daughter gets home with glove box key.
> Thanks, gerry[/color]
The place that you are taking the car to seems to think that something is
amiss with the ignition system so I'll give them the benefit of the doubt
and assume that they are finding a no spark condition.
Engines need 3 things to operate - fuel, air, and ignition, all at the
proper moment.
What brand are the various ignition parts?
Igniters tend to fail for good, not intermittently.
Is there any engine oil in the distributor?
Ray O
Old 05-07-2006, 03:54 AM   #3 (permalink)
LAZO
Guest
Posts: n/a
View LAZO's Photo Gallery
[url]http://groups.google.com.tr/group/Taner___53_01?lnk=li&hl=tr[/url]
Old 05-07-2006, 08:51 AM   #4 (permalink)
G Evans
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:ce215$445d69a5$180fead6$5407@msgid.meganewsservers.com...[color=blue]
> news:125purblkse9m80@corp.supernews.com...[color=green]
>> one works for two start ups then nothing, wait for tow truck, tow truck
>> driver and I try to start it and it starts, drive for 2 days then guess
>> what no fire up, waited 20 minutes then fired up went straight to garage,
>> he says it may have been a loose wire and it should be fine now, goes 5
>> days and same thing mechanic visits car he can't start it, he tows it in
>> to his shop, he tries it at the shop and it starts. says he can't fix it
>> now that it starts, I take it home it is in my garage, I am going over
>> the ignition wires with a fine tooth comb right now but would appreciate
>> any one who can tell me what is going on. I will look at ecu for loose or
>> damaged wires as soon as daughter gets home with glove box key.
> and assume that they are finding a no spark condition.[/color]
Thats what they tell me[color=blue]
> proper moment.
> What brand are the various ignition parts?[/color]
original[color=blue]
> Igniters tend to fail for good, not intermittently.[/color]
That's what I think as well[color=blue]
> Is there any engine oil in the distributor?[/color]
No.
[color=blue]
> Ray O
>[/color]
Old 05-07-2006, 11:53 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:125rran165sht01@corp.supernews.com...[color=blue]
> news:ce215$445d69a5$180fead6$5407@msgid.meganewsservers.com...[color=green]
>> news:125purblkse9m80@corp.supernews.com...[color=darkred]
>>> but no fire up, towed to garage, new rotor cap and wire, works fine till
>>> 2 weeks ago, same thing turns over no fireup, tow to garage, they play
>>> garage, he says it may have been a loose wire and it should be fine now,
>>> goes 5 days and same thing mechanic visits car he can't start it, he
>>> tows it in to his shop, he tries it at the shop and it starts. says he
>>> can't fix it now that it starts, I take it home it is in my garage, I am
>>> going over the ignition wires with a fine tooth comb right now but would
>>> appreciate any one who can tell me what is going on. I will look at ecu
>>> for loose or damaged wires as soon as daughter gets home with glove box
>>> key.
> Thats what they tell me[color=green]
>> proper moment.
> original[color=green]
> That's what I think as well[color=green]
> No.
>[color=green]
>> Ray O
>>[/color][/color]
They are going to need an ignition system wiring diagram in order to check
every circuit. I'd suspect the coil or a loose wire somewhere between the
coil and distributor.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Problems starting 94 toyota tercel Gordon Tercel, Paseo, Starlet, and Sera Forum 27 08-26-2006 12:58 PM
starting problems tacoma-05 2nd Generation (2005+) 68 04-28-2006 05:42 PM
1991 Corolla has Occassional Problems Starting PoopEater Archived Corolla threads 5 01-08-2006 07:22 PM
Tercel 94 Starting problems alxv Tercel, Paseo, Starlet, and Sera Forum 1 10-05-2005 02:43 PM
starting problems mr2trbo93 MR2 Forum 9 06-13-2005 12:26 AM
