Re: Power oil change?????
On 8 May 2006 10:24:29 -0700, [email]timbirr@mailcity.com[/email] wrote:
[color=blue]
>Are you talking about tranny fluid or engine oil.
>The quick lube places love to sell things that power engine flushes,
>etc. In a typical oil change a small amount of oil stays in the
>engine, but not enough to worry about. If that is what you are talking
>about, save your money and change your oil a little more frequently.
>If you are talking 'bout tranny, there is an advantage as a significant
>amount of fluid remains if you just do the standard drain from the pan.
>When you drain the pan through the drain plug you will only drain about
>a third or less of the total. Most of the fluid is inside the torque
>converter, transmission cooler and the cooler lines.
>Some vehicles have a drain plug on the torque converter so it can be
>drained, but not many of them, so a special flush is the way to get all
>the fluid out of the transmission so you can replace it with new fluid.
>Does it really help keep the tranny going longer? I don't really know,
>but considering you only do it at the standard interval, which in my
>rig is 30K, I don't mind spending the $60 for the complete change. I
>would recommend you have it done by a real mechanic, not a quick change
>artist.[/color]
Is any of this suggested for Toyota cars by anybody?
