Steering noises/vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2006, 05:04 AM   #1 (permalink)
FantomFan
Guest
Posts: n/a
View FantomFan's Photo Gallery
I have a Japanese assembled 1996 Toyota Corona Premio (AT211 automatic with
7A-FE engine) which is making a noise which appears to come from the top of
the steering column. The noise is associated with what I would describe as
a judder (most common when returning from a left hand turn).
Power steer fluid level is correct, belt is correctly adjusted (as far as I
can tell).
Any suggestion as to where to start or how to check/lubricate upper bearing
Old 05-09-2006, 02:17 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Steering noises/vibration
"FantomFan" <reaper_nz@hotmail.com> wrote in message
news:e3p9i2$rhs$1@lust.ihug.co.nz...[color=blue]
> "Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
> news:3b6fe$445ec5d2$180fead6$18032@msgid.meganewsservers.com...[color=green]
>> news:e3kd6k$qsd$1@lust.ihug.co.nz...[color=darkred]
>>>with 7A-FE engine) which is making a noise which appears to come from the
>>>top of the steering column. The noise is associated with what I would
>>>describe as a judder (most common when returning from a left hand turn).
>>> as I can tell).
>>> bearing[/color]
>> It is difficult to diagnose the condition without experiencing it
>> firsthand, but some things to check are the universal joints for the tilt
>> steering column mechanism and in the engine compartment for binding; rack
>> ends and ball joints for excessive play; tires for abnormal wear and
>> bumps; CV joints for play or binding.
>> Ray O
>> (correct punctuation to reply)
>>[/color]
> Thanks Ray,
> Here's a bit more info if it helps.
> Just had a hand on each side of the steering wheel and tried to wobble it,
> made a noise similar to two ball bearings hitting each other.
> Does this help any with the diagnosis?[/color]
I can't say that I've ever heard the sound you're describing under the
conditions you're describing. If it sounds like the noise is coming from
the top of the steering column, you might want to try removing the steering
column cover. There are usually screws on the underside of the steering
column cover that go through to the top half of the cover. With the covers
removed, you may be able to see what the cause of the noise is. Also, place
one hand on the turn signal stalk while you move the steering wheel and see
if you can feel anything on the turn signal stalk. The sound may be coming
from the mechanism that turns off the turn signal when centering the
steering wheel. If the sound is coming from near the steering wheel, there
is also a device that looks like a clock spring for the air bag that rotates
and may be loose. If the sound is coming from closer to the dashboard, the
cause might be the universal joint for the tilt steering wheel.
Good luck!
Ray O
Old 07-02-2006, 05:31 AM   #3 (permalink)
FantomFan
Guest
Posts: n/a
news:40270$446033ea$180fead6$31790@msgid.meganewsservers.com...[color=blue]
> news:e3p9i2$rhs$1@lust.ihug.co.nz...[color=green]
>> news:3b6fe$445ec5d2$180fead6$18032@msgid.meganewsservers.com...[color=darkred]
>>>>the top of the steering column. The noise is associated with what I
>>>>would describe as a judder (most common when returning from a left hand
>>>>turn).
>>>> as I can tell).
>>>> bearing
>>> tilt steering column mechanism and in the engine compartment for
>>> binding; rack ends and ball joints for excessive play; tires for
>>> abnormal wear and bumps; CV joints for play or binding.
>>> Ray O
>>>[/color]
>> Thanks Ray,
>> it, made a noise similar to two ball bearings hitting each other.
> steering column cover. There are usually screws on the underside of the
> steering column cover that go through to the top half of the cover. With
> the covers removed, you may be able to see what the cause of the noise is.
> Also, place one hand on the turn signal stalk while you move the steering
> wheel and see if you can feel anything on the turn signal stalk. The
> sound may be coming from the mechanism that turns off the turn signal when
> centering the steering wheel. If the sound is coming from near the
> steering wheel, there is also a device that looks like a clock spring for
> the air bag that rotates and may be loose. If the sound is coming from
> closer to the dashboard, the cause might be the universal joint for the
> Good luck!
> Ray O
>[/color]
Update on this - I had another look earlier and the clicking noise (like two
metal balls contacting) was coming from the lower end of the column.
I squirted some CRC 5.56 back up the tube and the noise seems to have
disapeared for now.
Is there a bearing in there that may need more attention?
Old 07-02-2006, 01:26 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:e883nu$ho3$1@lust.ihug.co.nz...[color=blue]
> news:40270$446033ea$180fead6$31790@msgid.meganewsservers.com...[color=green]
>> news:e3p9i2$rhs$1@lust.ihug.co.nz...[color=darkred]
>>>>>turn).
>>>>> as I can tell).
>>>>> bearing
>>>> Ray O
>>> Thanks Ray,
>> is. Also, place one hand on the turn signal stalk while you move the
>> steering wheel and see if you can feel anything on the turn signal stalk.
>> The sound may be coming from the mechanism that turns off the turn signal
>> when centering the steering wheel. If the sound is coming from near the
>> Good luck!
>> Ray O
>>[/color]
> two metal balls contacting) was coming from the lower end of the column.
> disapeared for now.
> Is there a bearing in there that may need more attention?[/color]
I am not familiar with your car as it is not sold in the U.S. There is
probably a universal joint in the steering shaft in the engine compartment
that sometimes makes noises or binds, and another u-joint on the interior
side for the tilt steering column. There is dust seal where the column
passes through the firewall, and a bearing or bushing at the upper end of
the column, near the steering wheel. There is also a steering locking
mechanism linked to the ignition lock that may be hanging up. I think the
steering lock engages the shaft at the lower end of the column somewhere; it
sounds like this is where you sprayed so this may be what you hit with the
lubricant.
BTW, the screws that hold the steering column cover in place may be behind
the steering wheel. If so, turn the wheel 90 degrees to expose the screws
at the end of the column.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 01:34 PM
Steering going bad? Odyman 2nd Generation (2005+) 2 11-08-2005 03:09 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 02:17 AM
Power Steering Checklist help blazin_azn MR2 Forum 14 06-13-2005 10:31 AM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 08:38 AM
