{OT}Another Pool Water Tip - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2006, 03:58 AM   #1 (permalink)
=?iso-8859-1?Q?mark=5Fdigital=A9?=
Guest
Posts: n/a
View =?iso-8859-1?Q?mark=5Fdigital=A9?='s Photo Gallery
This past week I've been a little worried about why it was taking so long
for the pool water to go from cloudy to clear after I removed the winter
cover. The filter wouldn't self prime either although all the fittings and
tubing were water tight. It would start and run fine as long as I was there
to prime it.
Well, it appears the two problems are related. I was using leftover DE that
was stored in the same shed I store my outdoor stuff like lawnmower,
chainsaw, snowthower, and spare gasoline and K-1.
I should have investigated why the one pound scooper felt much heavier when
filled with DE but I simply passed it off as maybe water moisture, much like
flour will have on some days more than others (explains why your favorite
pizza shop screws up the crust once in awhile).
DE is inert. It is not combustible. It doesn't carry the same safety
warnings as, let's say, storing chlorine or acid. But it does absorb
contaminants from the air as when it's put to use filtering water.
So I'm happy to pass on to you my experience by saying keep your DE tightly
wrapped in a plastic bag or transfer it to a large bucket with a tight lid.
I'd also like to pass on some advice given to me about electronic robot
cleaners. Just about anyone who has one probably noticed it gets sluggish
and won't climb the walls when the pool water is cold. A tech told me the
motors aren't designed to operate in water less than 60 degrees and the oil
inside the motors thicken hampering it's performance which conceivably could
shorten it's lifespan.
BB code is Off
Smilies are Off
[IMG] code is Off
Detailing your vehicle (Exterior) Pb Detailing & Car Care 222 05-15-2011 08:50 PM
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
Echo 2000 check engine light Raistlin Yaris, Vitz and Echo Forum 19 03-26-2007 05:33 PM
Water spill....carpool carwash asking $350 to fix png6778 General Discussion 10 05-04-2006 11:08 PM
