Brake Fluid - Maintenance Sched. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2006, 07:32 PM   #1 (permalink)
DonLogan
Guest
Posts: n/a
View DonLogan's Photo Gallery
I don't see anything about change intervals for brake fluid in my
owners book (93 4runner). Any recommendations - miles - months? Can't
last forever, one wouldn't think.
thanks
Old 05-10-2006, 11:22 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Brake Fluid - Maintenance Sched.
"DonLogan" <xxx@> wrote in message
news:hc15625uhdub9knf5622rrms28323dhutk@4ax.com...[color=blue]
> thanks[/color]
If the brake system is sealed, the fluid will theoretically last forever.
In the real world, the fluid absorbs moisture from the air and so changing
the fluid every 3 or 4 years or every other brake pad change is a good idea.
Ray O
Old 05-11-2006, 12:22 AM   #3 (permalink)
Viperkiller
Guest
Posts: n/a
View Viperkiller's Photo Gallery
On Wed, 10 May 2006 23:22:47 -0500, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>news:hc15625uhdub9knf5622rrms28323dhutk@4ax.com...[color=green]
>> thanks[/color]
>the fluid every 3 or 4 years or every other brake pad change is a good idea.[/color]
....or if it has already turned black.
Old 05-11-2006, 04:54 AM   #4 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
Viperkiller wrote:
[color=blue]
> ...or if it has already turned black.[/color]
The only reason for it to turn black is if your flexi-hoses are
collapsing internally, i have an open tub of brake fluid i left out in
the garden for about 3 months - rain or shine - and it hasnt changed
colour much. Still looks like fresh engine oil, used to look like a
fine virgin olive oil.
J
Old 05-12-2006, 12:27 AM   #5 (permalink)
RT
Guest
Posts: n/a
View RT's Photo Gallery
On Wed, 10 May 2006 20:32:29 -0400, DonLogan <xxx@> wrote:
[color=blue]
>thanks[/color]
I change it every 2 years, but that's overkill. It's cheap and easy to
do. At the maximum I would say 4 years but that's probably pushing it.
If you don't do it you will likely be awarded with costly abs repairs.
Old 05-12-2006, 04:48 AM   #6 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message news:ee229$4462bcbe$180fead6$17434@msgid.meganewsservers.com...[color=blue]
> "DonLogan" <xxx@> wrote in message news:hc15625uhdub9knf5622rrms28323dhutk@4ax.com...[color=green]
>> thanks[/color]
> If the brake system is sealed, the fluid will theoretically last forever. In the real world, the fluid absorbs moisture from the
> air and so changing the fluid every 3 or 4 years or every other brake pad change is a good idea.
> Ray O
> (correct punctuation to reply)[/color]
If the brakes are done in shop those power bleeders pump a lot of brake fluid thru too.
Come to think of it my 1987 Supra still has the original brake fluid.. lol...
Old 05-12-2006, 09:33 AM   #7 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
In our fleet service business we changed brake fluid every two years, or 75K
WOF, in those vehicles that use DOT 3. If one uses DOT 5, there is no need
to change the brake fluid because water will migrate to the top and
evaporate
mike hunt
> thanks[/color]
Old 05-12-2006, 10:10 AM   #8 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
I did some research on this a few months back, having to replace the entire
hydraulic system of a vintage Willys. One thought was to use DOT5 as it is
incompatible with DOT3 and 4 requiring complete replacement of the hydraulic
system to upgrade anyway, is not hygroscopic and does not need changing
There is some indication that DOT5 may be phased out by the US military & if
so could become difficult / impossible to find in the civilian world.
While DOT3 and DOT4 are hygroscopic they aren't strongly so; furthermore
they contain anticorrosives which generally last about two years before
losing their effectiveness.
Based on my research I chose to go with DOT3. I intend to change it every
two years with new DOT3 from a sealed container; when topping up I will add
from a tightly closed but not necessarily factory sealed bottle.
Mike Harris
Austin, TX
"Mike Hunter" <mikehunt2@mailcity.com> wrote in message
news:THGdnUVCAfQoAfnZUSdV9g@ptd.net...[color=blue]
> 75K WOF, in those vehicles that use DOT 3. If one uses DOT 5, there is no
> need to change the brake fluid because water will migrate to the top and
> evaporate
> mike hunt
>> thanks[/color]
>[/color]
Old 05-12-2006, 01:05 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
"RT" <noyabusiness@yahoo.com> wrote in message
news:237862t4h06gsnkc8lags20v4mvc1oq244@4ax.com...[color=blue]
>[color=green]
>>thanks[/color]
>[/color]
I disagree that it is likely that a vehicle will need ABS repairs if the
fluid is not changed after 4 years. I have yet to see or hear of an ABS
actuator needing replacement for any reason, let alone due to the lack of
brake fluid changes. On the other hand, I have seen calipers and brake
cylinders get corroded due to lack of fluid changes.
Ray O
Old 05-12-2006, 06:52 PM   #10 (permalink)
RT
Guest
Posts: n/a
On Fri, 12 May 2006 13:05:42 -0500, "Ray O"
[color=blue]
>news:237862t4h06gsnkc8lags20v4mvc1oq244@4ax.com...[color=green]
>>[color=darkred]
>>>thanks[/color]
>>[/color]
>fluid is not changed after 4 years. I have yet to see or hear of an ABS[/color]
I didn't say after 4 years. I said if you don't do it. read.
[color=blue]
>cylinders get corroded due to lack of fluid changes.[/color]
I've seen several abs systems that broke down. All of them had never
had the brake fluid replaced. People think cars only need oil changes.
Old 05-12-2006, 11:23 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:1r7a62hbfu2gmcsv406aj0h0iub8t6sqok@4ax.com...[color=blue]
>[color=green]
>>news:237862t4h06gsnkc8lags20v4mvc1oq244@4ax.com...[color=darkred]
>>>>thanks
>>>[/color]
> I didn't say after 4 years. I said if you don't do it. read.[/color]
I didn't say the ABS would fail after 4 year either. read. ;-)
[color=blue]
>[color=green]
>[/color]
What broke down in the ABS systems you saw? What model vehicles? BTW, I
agree on the need to change brake fluid.
Ray O
Old 05-12-2006, 11:49 PM   #12 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Thu, 11 May 2006 22:27:10 -0700, RT <noyabusiness@yahoo.com> wrote:
[color=blue]
>If you don't do it you will likely be awarded with costly abs repairs.[/color]
Not those of us that don't have or care to have ABS.....
Scott in Florida
BB code is Off
Smilies are Off
[IMG] code is Off
How does brake fluid work? touringcamry General Discussion 7 04-17-2006 08:32 PM
clutch and brake fluid rice Archived Corolla threads 2 12-03-2005 02:47 PM
Brake Fluid in Power Steering Resevior acg Camry & Solara Lounge 4 11-22-2005 05:30 PM
Brake Fluid Problem dna59 Camry & Solara Lounge 2 05-22-2005 10:02 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
