1993 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2006, 03:59 PM   #1 (permalink)
Ralph
Guest
Posts: n/a
View Ralph's Photo Gallery
1993 Corolla
Jack wonders: Re: 1993 Corolla; 227,000 km
I would like to lift the back of the car a bit, and stiffen it when towing
my utility trailer. It tends to sag a bit even with only 100 lb on the
tongue.
I have put on aftermarket gas shocks already.
In 2003 I put on a transmission cooler (it's a 'medium' size but rated for a
4000 lb trailer if I recall). Since then the engine has run below medium
operating temperature almost all the time. Why is this? Is it a problem? Is
there a way to verify that I hooked the cooler up correctly (downstream from
the rad)?
By the way, I wasn't able to look up the trans. fluid change interval on the
Toyota website because my car is too old (1993) for their list. So, I would
like to find out what the interval is.
Your comments are invited.
Thanks,
- Jack
Old 05-12-2006, 05:00 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1993 Corolla
"Ralph" <nospam@thanks.com> wrote in message
news:4464f735$1_1@news.cybersurf.net...[color=blue]
> tongue.
> I have put on aftermarket gas shocks already.[/color]
Shock absorbers do not support the weight of the car; springs or struts
support the weight of the car.
If you want to adjust the ride height of the vehicle, then add an air bag
type suspension or change the springs.
[color=blue]
> a 4000 lb trailer if I recall). Since then the engine has run below
> medium operating temperature almost all the time. Why is this? Is it a
> problem? Is there a way to verify that I hooked the cooler up correctly
> (downstream from the rad)?[/color]
As long as the engine and emissions system is fully warmed up, having the
engine run a little below medium operating temperature is not a big problem.
There is a difference between warming up quickly and then holding below the
optimal temperature and taking a long time to warm up. If it takes a long
time to warm up, make sure the cooling fan is not running all the time and
that the thermostat is the correct one and not stuck.
[color=blue]
> the Toyota website because my car is too old (1993) for their list. So, I
> would like to find out what the interval is.
> Thanks,
> - Jack[/color]
If you are towing a trailer, I would change the ATF every 24,000 miles.
Ray O
Old 05-12-2006, 07:37 PM   #3 (permalink)
RT
Guest
Posts: n/a
View RT's Photo Gallery
Re: 1993 Corolla
On Fri, 12 May 2006 16:59:31 -0400, "Ralph" <nospam@thanks.com> wrote:
[color=blue]
>tongue.
>operating temperature almost all the time. Why is this? Is it a problem? Is[/color]
might be a coincidence. When was the last time the thermostat has been
replaced ? and a good flush won't hurt either.
[color=blue]
>the rad)?[/color]
A transmission cooler cools the transmission, not the engine.[color=blue]
>Thanks,
>- Jack
>[/color]
Old 05-13-2006, 09:28 PM   #4 (permalink)
Ralph
Guest
Posts: n/a
Re: 1993 Corolla
Thankyou gentlemen,
- Jack
BB code is Off
Smilies are Off
[IMG] code is Off
sticky windows in 1993 corolla celica2004 Archived Corolla threads 1 09-17-2005 12:57 PM
Short vid of my 4AGZE corolla! mhiscott Archived Corolla threads 12 08-26-2005 06:09 PM
Questioning the 2006 Corolla again...... RAV4EVR Toyota News 16 08-01-2005 12:26 PM
FS: 1993 Toyota Corolla - Sedan and Wagon Astroboy Vehicles 1 10-14-2004 10:35 AM
