Re: Toyota Highlander rattle in the rear
"JohnR66" <nospam@att.net> wrote in message
news:n7c9g.54287$Fs1.31378@bgtnsc05-news.ops.worldnet.att.net...[color=blue]
> It is an 02 and when driving over rough pavement or a stone driveway,
> there is a pronounced rattle from the rear. Perhaps a suspension
> component.
> I Googled and found dashboard rattles, but not the problem here so I guess
> it is uncommon. Anyone else have this problem with their highlander? What
> was the actual souce of the rattle?
> Thanks, John[/color]
Rear rattles in hatchbacks and station wagons generally come from these
sources:
Something loose in a compartment, like the jack, tools, jumper cables, etc.;
Rear hatch mis-adjusted;
Spare tire loose (either not screwed down tightly if in a well or not
winched up all the way if hanging underneath);
Wire loom or wire harness connector rattling (pad with foam or secure with
duct tape or zip ties).
If the sound is coming from the top of the strut mount, loose, deformed, or
hardened suspension bushings.
Ray O
