Re: 01 Sienna engine light on, vacum switch valve then oxygen sensor
Ray .. thx. P0183 may not be right one, but the mechanic had pointed
out to me the sensor is right after the conveter, I noticed one of the
screw is rusted but still very tied.
Funny things is that after I shake the sensor (try to remove rust) and
engine light turn off after two days. I guess it does point to a bad
connection or bad sensor. what confuse me is that may guy compliant
replace a O2 sensor useless and some expert claim only <10% of O2
sensor really need change.
Henry
Ray O wrote:[color=blue]
> "henry" <hzhong2@yahoo.com> wrote in message
> news:1147831988.672258.82120@38g2000cwa.googlegroups.com...[color=green]
> > my 01 Sienna last month showed engine light on, went to dealer to fix
> > and been told code P0446 need replace by pass vacum switch valve. cost
> > 300 and good for 3 weeks and shows light on again.[/color]
> P0446 means that there is a malfunction in the Evaporative Emission Control
> System Vent Control Circuit. This could be the result of overfilling the
> fuel tank.
>[color=green]
> > from Google chat tried to tighten the gas cap and 3 days later light
> > off but only good for 2 days; went to dealer again, this time read
> > (P0183?) is oxygen sensor need replacedm, 400!
> > but seems to me they just read a code and then guess/try to fix with
> > replacing part but never
> > show what is wrong with old part. I refused the fix this time casue I
> > may simply pay 300 per month to lease one. never know next month which
> > code will show up.[/color]
> P0183 has nothing to do with the oxygen sensor. P0183 means Fuel
> Temperature Sensor A Circuit High Input
> There are other codes for oxygen sensor troubles and guessing the code is
> just a waste of time. You will need to write down the trouble code to get
> an informed response to your question.
>[color=green]
> > question and help need here:
> > is it normal that replace VSV or Oxgen sensor like routine oil change
> > (affortable at least) ?[/color]
> It depends on how the vehicle was maintained, its age, and mileage.
>[color=green]
> > does Toyota cover to fix emission related problem if my car failed to
> > emission test?[/color]
> Check your warranty manual for emissions warranty. Certain components are
> covered for 8 years/80,000 miles from the date of first use. I don't think
> the oxygen sensor or vacuum switching valve are covered though.
>[color=green]
> > dose anybody ask Toyota for recall about these engine light on
> > triggered by emission related part?
> > is this only Toyota Sienna problem or it is generic issue.
> > thanks
> >[/color]
> No manufacturer will recall vehicles just because a few vehicles had
> emissions related parts failures. If a lot off vehicles experience the same
> failure, then the manufacturer may issue a recall.
> Ray O
> (correct punctuation to reply)[/color]
