Toyota corolla 99 - Grinding noise from right front wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2006, 11:02 PM   #1 (permalink)
auto4toyota
Guest
Posts: n/a
View auto4toyota's Photo Gallery
The passenger side front wheel makes a grinding noise when ever the car
is in motion. It seems like the brake pads are touching the rotor when
the vehicle is running. I have replaced the front pads and rotors with
OEM parts. I have taken it to the mechanic several times and they open
up the brakes and say everything is fine, the car runs without noise
for a day or two and again the noise starts. Any ideas as to what is
the cause of this problem?? has the calipers gone bad and how can i
test for the calipers. Replies are appreciated.
Thanks,
Guru
Old 05-17-2006, 12:16 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota corolla 99 - Grinding noise from right front wheel
"auto4toyota" <guru.sati@gmail.com> wrote in message
news:1147838522.166808.262210@i40g2000cwc.googlegroups.com...[color=blue]
> Thanks,
> Guru
>[/color]
When you replaced the pads and rotors, you did orient the wear indicators
properly, install all of the shims and springs, and lube the caliper slide
bolts with wheel bearing grease or anti-seize, right? Did the noise start
after you did the brake job or was it there before? Check to make sure the
backing plate is not touching the rotor. This is what I'd check first.
A bad caliper will either leak brake fluid, or the caliper piston will seize
in the bore. If the caliper is not leaking and you can push the piston back
into the bore, then it is OK.
Ray O
Check the CV joints to make sure the boots are not torn and that they are
not dry.
Old 05-19-2006, 09:55 AM   #3 (permalink)
Guest
Posts: n/a
View 's Photo Gallery
> Thanks,
> Guru
>[/color]
You could try putting caliper grease on the caliper sliders, that might
help. On my 99 Corolla the rubber boots seem to be glued in/ permanently
installed on the caliper so I just pulled out the slider, applied the grease
and put it back in. Doing this eliminated some vabriation I was getting
when braking downhill or on hard braking.
BB code is Off
Smilies are Off
[IMG] code is Off
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
99 Corolla Front SPeaker Mounting Depth rumin8 Audio, Video, and Security - Tech 1 10-24-2005 02:36 PM
Toyota's global strategy looks inward rolla-XRS Toyota News 7 11-29-2004 03:55 PM
99 Corolla low-speed front end noise wmcot Archived Corolla threads 8 11-15-2004 11:31 AM
Front wheel noise slipp Camry & Solara Lounge 5 10-19-2004 11:14 PM
