toyota starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2006, 08:15 PM   #1 (permalink)
thebarrs4@verizon.net
Guest
Posts: n/a
View thebarrs4@verizon.net's Photo Gallery
I have a 92 toyota camry. I have replaced the ignition coil 3 times
now. It gets a weak spark from the ignition to the coil and won't turn
over. help!
Old 05-18-2006, 09:08 PM   #2 (permalink)
jakdedert
Guest
Posts: n/a
View jakdedert's Photo Gallery
Re: toyota starting problem
[email]thebarrs4@verizon.net[/email] wrote:[color=blue]
> over. help!
>[/color]
Research your definitions and get back to us...no seriously, an engine
'turns over' when the starter makes it do so. The coil has nothing to
do with it. I'd guess what you really mean is that it 'turns over' but
doesn't 'hit', 'catch' or START.
Given what you know, I'm suspicious of your diagnosis....
Old 05-19-2006, 12:05 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<thebarrs4@verizon.net> wrote in message
news:1148001316.381999.267340@g10g2000cwb.googlegroups.com...[color=blue]
> over. help!
>[/color]
As jakededert mentioned, your automotive terminology is pretty confused.
The spark does not go from the ignition to the coil. The current goes from
the coil to the distributor cap and then to the spark plugs, where the spark
is created.
The common meaning for "turn over" is a synonym for cranking the engine.
When you say "turn over," do you mean that the engine cranks but will not
start?
Why did you replace the ignition coil 3 times? Were the replacements an
attempt to get a spark? Were the ignition coils genuine Toyota parts or
aftermarket parts? Are the distributor cap, rotor, spark plug wires, and
spark plugs genuine Toyota parts or aftermarket parts. Aftermarket parts
sometimes cause a weak spark or other ignition-related problems.
for an engine to run, you need air, fuel, and a source of ignition, all at
the appropriate times.
I recommend that you have the car professionally diagnosed.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
05 Corolla starting problem phil 9th Generation (2003-2008) 677 Today 05:29 PM
Toyota's Dyin out Valentino Celica Forum 16 07-23-2007 11:36 PM
Intermittent Problem Starting 94' Celica villain189 Celica Forum 1 03-16-2005 03:31 PM
Ford, Nissan license Toyota hybird technology EKam Toyota News 1 01-30-2005 03:25 PM
