Re: Toyota Corrola 1984 - Engine Overheating
BEFORE you start the car in the morning, or after it has been parked long
enough to cool down, open the radiator itself and check for coolant. Fill
the coolant (avoid water if you can) to about 1.5 inches from the the top of
the filler neck, then put the cap back on and fill the reservior bottle to
the line indicated on the outside.
After that, buy a 6-pack for a friend, and have him or her take a look at
your car for you. In yoiur first sentence, you say you rchecked all of the
obvious things, but later you said you don't know anything about cars. I
have to wonder what the obvious things are to a person that knows nothing.
"dekock" <a.j.de-kock@ntlworld.com> wrote in message
news:2962192ff2d5167917a52560bbe09e37@localhost.talkaboutautos.com...[color=blue]
>I have checked all obvious things and the engin is till overheadting... ie
> oil, water etc?It overheats as soon as I start driving. Should I put water
> in the radiator, there is a little tube running to it from the water tank
> but there doesn't seem to be any water in it? is there anything else I can
> check, also I don't know anything about cars but really cannot afford to
> take it to a shop to get fixed, just had MOT done so it really should be
> playing up. I could do with any advice!
> many thanks
>[/color]
