power steering leak, how to find what part is leaking? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2006, 06:08 PM   #1 (permalink)
dpatwa@gmail.com
Guest
Posts: n/a
View dpatwa@gmail.com's Photo Gallery
I'm losing about 6 oz of power steering fluid every 2 days from my 97
camry. Generally, at work and home where my car sits the longest,
there is usually a noticable puddle. One mechanic has said that the
leak is from the power sterring rack and pinion. will mechanics
replace this or repair it? How do I find out exactly where the leak is
coming from? is it possible that a there is a bad hose between the PS
fluid container and other parts? does any recommendations on how to
better diagnose this since the fix is very expensive?
-Thanks
Old 05-28-2006, 06:57 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: power steering leak, how to find what part is leaking?
<dpatwa@gmail.com> wrote in message
news:1148854104.727047.204550@i39g2000cwa.googlegroups.com...[color=blue]
> -Thanks
>[/color]
It is possible to repair the steering rack and pinion assembly, however, you
need special tools and a very clean environment, and the success rate of
field repairs is not very high so most shops replace the rack rather than
make a low percentage attempt at repair.
You can find exactly where the leak is coming from by cleaning up the leaks
and watching where the power steering fluid is coming from. If you place a
piece of cardboard under the ends of the power steering rack, you can see if
it becomes stained from leaks. The most common places for racks to leak is
at the ends.
It is possible for a hose, hose connection, or power steering pump to leak
but the rack ends are the most common location for power steering fluid
leaks.
As I mentioned, the best way to diagnose the leak is to clean up all of the
previous leaks and see where the fluid is coming from.
You can ask the shop working on your car if they can find an aftermarket
rack or a factory remanufactured rack.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
'93 Camry Power Steering Problem joeantispam 3rd & 4th Generation (1992–1996 & 1997–2001) 20 10-23-2011 08:34 PM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 12:30 PM
'95 Camry appears to be leaking power steering fluid, Suggestions? 95CamryLE 3rd & 4th Generation (1992–1996 & 1997–2001) 14 10-23-2006 10:38 PM
05 Power Steering Leak 05Limited 3rd Generation (2005-2012) 1 10-21-2005 06:09 PM
How hard is it to convert to power steering? Camdaddy MR2 Forum 21 10-13-2004 10:29 PM
