New Sienna CE 06 - Have questions. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2006, 08:08 PM   #1 (permalink)
joe
Guest
Posts: n/a
View joe's Photo Gallery
1.
How do I disconnect the close door buzzer - the indicator light is
enough for me? Any downside to doing this?
2.
No place in the Owners Manual dos it mention about any problem
overfilling the gas tank. Is it?
3.
In the manual it says one can use plain water for the windshield
washer. Is that a good thing? Is there any problem with overfilling
it - it does have a nice riser tube.
Regards,
joe
Old 05-29-2006, 01:19 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: New Sienna CE 06 - Have questions.
"joe" <nospam@invalid.com> wrote in message
news:sdek72h6hnh2560ln2b9kfqo96he9ohj3e@4ax.com...[color=blue]
> 1.
> enough for me? Any downside to doing this?[/color]
Most buzzers are merely plug-in devices that can just be pulled out of the
socket.
[color=blue]
> 2.
> overfilling the gas tank. Is it?[/color]
If you often overfill the gas tank, not only are you spilling fuel with the
associated environmental problems, there is a slim chance that you can
saturate the charcoal canister.
[color=blue]
> 3.
> Regards,
> joe[/color]
Plain water is not as effective at cleaning the windshield as windshield
washer fluid and plain water will freeze in winter so you have to remember
to add windshield washer fluid before it gets cold. The problem with
overfilling windshield washer fluid is that it can ruin the paint where it
overflows. I believe that the windshield washer reservoir will hold a
gallon so you really have to add a lot to overfill the reservoir.
Ray O
Old 05-29-2006, 01:40 AM   #3 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
Windshield wiper fluid that doesn't get diluted should not be capable of
damaging paint. After all, it ends up on your car paint after being wiped
off your windshield.
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message
news:c71a0$447a8459$180fead6$7446@msgid.meganewsservers.com...[color=blue]
> news:sdek72h6hnh2560ln2b9kfqo96he9ohj3e@4ax.com...[color=green]
>> 1.
> socket.
>[color=green]
>> 2.
> the associated environmental problems, there is a slim chance that you can
>[color=green]
>> 3.
>> Regards,
>> joe[/color]
> Ray O
>[/color]
Old 05-29-2006, 10:49 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
"Art" <begunaNOSPAMPLEASE@mindspring.com> wrote in message
news:LPveg.6332$921.3339@newsread4.news.pas.earthlink.net...[color=blue]
>[/color]
The windshield washer fluid that is wiped off of the windshield generally
gets dispersed and so it doesn't really damage paint. Washer fluid that is
spilled near the washer fluid reservoir tends to pool and when it dries, it
leaves a crusty blue stain on the paint. It is not as unsightly under the
hood as it would be on the outer body, but nevertheless, all one has to do
to avoiod the problem is to not overfill the washer fluid reservoir.
Ray O
[color=blue]
> news:c71a0$447a8459$180fead6$7446@msgid.meganewsservers.com...[color=green]
>> news:sdek72h6hnh2560ln2b9kfqo96he9ohj3e@4ax.com...[color=darkred]
>>> 1.
>> the socket.
>>[color=darkred]
>>> 2.
>> can saturate the charcoal canister.
>>[color=darkred]
>>> 3.
>>> Regards,
>>> joe[/color]
>> remember to add windshield washer fluid before it gets cold. The problem
>> with overfilling windshield washer fluid is that it can ruin the paint
>> where it overflows. I believe that the windshield washer reservoir will
>> hold a gallon so you really have to add a lot to overfill the reservoir.
>> Ray O
>>[/color]
>[/color]
Old 05-29-2006, 11:44 AM   #5 (permalink)
Art
Guest
Posts: n/a
news:e730c$447b0ea3$180fead6$27030@msgid.meganewsservers.com...[color=blue]
> news:LPveg.6332$921.3339@newsread4.news.pas.earthlink.net...[color=green]
>> wiped
>>[/color]
> is spilled near the washer fluid reservoir tends to pool and when it
> dries, it leaves a crusty blue stain on the paint. It is not as unsightly
> under the hood as it would be on the outer body, but nevertheless, all one
> has to do to avoiod the problem is to not overfill the washer fluid
> reservoir.
> Ray O
>[/color]
Your engine compartment is probably cleaner than the outside of my
car........
Old 05-29-2006, 12:20 PM   #6 (permalink)
joe
Guest
Posts: n/a
On Mon, 29 May 2006 00:19:02 -0500, "Ray O"
<rokigawa@tristarassociatesDOTcom> wrote:
[color=blue]
>> 1.
>socket.[/color]
Thanks - do 'we' know where that buzzer is located? Is it on the end
of a wire or on a circuit board with a lot of other 'salad'? Under
the hood or ??
[color=blue]
>[color=green]
>> 2.
>[color=green]
>> 3.
>> Regards,
>> joe[/color]
>gallon so you really have to add a lot to overfill the reservoir.[/color]
Old 05-29-2006, 12:25 PM   #7 (permalink)
joe
Guest
Posts: n/a
[color=blue][color=green]
>> 2.
>[/color]
So one is just to stop filling at the automatic pump handle shut-off.
And not go to the nearest $10 after that.
j
Old 05-29-2006, 12:35 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:cu7m72pmidp13m6vksgtoagjoq7ljki6in@4ax.com...[color=blue]
>[color=green][color=darkred]
>>> 2.
>>the
>>[/color]
> j[/color]
I would definitely not go to the nearest $10 after the pump handle shuts
off. I would just go to the nearest 5 or 10 cents.
Ray O
Old 05-29-2006, 12:38 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
news:fl7m729gdrcnnl1ee0p0itgmlbl50g5eo5@4ax.com...[color=blue]
>[color=green]
>>> 1.
>>socket.[/color]
> the hood or ??
>[/color]
I do not know where the buzzer is located. The best way to find it is to
activate it and stick your head under the dashboard and use your fingers to
feel for the buzzing device.
I just thought of a possible downside, and that is the the auto door unlock
feature if you leave your key in the ignition may not work. This device
automatically prevents the power door locks from working if the engine if
off and the key is in the ignition.[color=blue]
>[/color]
Ray O
(correct punctuation to reply)overfill the reservoir.
Old 05-29-2006, 12:45 PM   #10 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Open the door, let it buzz, and look under the dash.
Old 05-29-2006, 12:46 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:KFEeg.9121$y4.6953@newsread2.news.pas.earthlink.net...[color=blue]
> news:e730c$447b0ea3$180fead6$27030@msgid.meganewsservers.com...[color=green]
>> news:LPveg.6332$921.3339@newsread4.news.pas.earthlink.net...[color=darkred]
>>> wiped
>>>[/color]
>> unsightly under the hood as it would be on the outer body, but
>> nevertheless, all one has to do to avoiod the problem is to not overfill
>>. Ray O
>>[/color]
> car........
>[/color]
The engine compartments of our cars are not pristine by any means. They are
pretty dusty, but I always wipe off spills so that any leaks and the sources
of those leaks will be evident right away. I fill the washer fluid until
the fluid touches the bottom of the basket screen - a few extra ounces to
fill it to the brim and spill over serves no purpose. The other fluid
reservoirs under the hood all have markings to indicate when the proper
fluid level is reached. I coat the battery terminals with a spray made for
that purpose so you do not get the acid buildup on the posts and clamps.
BTW, it is not actually the posts that weep acid; it is the space between
the battery case and posts that allows the acid fumes to escape so spraying
enough to coat that gap or using one of those treated felt washers that you
place under the clamp will help prevent the acid buildup on the posts.
Ray O
Old 05-29-2006, 12:54 PM   #12 (permalink)
joe
Guest
Posts: n/a
On Mon, 29 May 2006 11:35:11 -0500, "Ray O"
[color=blue]
>news:cu7m72pmidp13m6vksgtoagjoq7ljki6in@4ax.com...[color=green]
>>[color=darkred]
>>>> 2.
>>>the
>>>[/color]
>> j[/color]
>off. I would just go to the nearest 5 or 10 cents.[/color]
Thanks.
I was kidding about the high cost of gas.
j
Old 05-29-2006, 01:09 PM   #13 (permalink)
joe
Guest
Posts: n/a
On Mon, 29 May 2006 11:46:16 -0500, "Ray O"
[color=blue]
>news:KFEeg.9121$y4.6953@newsread2.news.pas.earthlink.net...[color=green]
>> news:e730c$447b0ea3$180fead6$27030@msgid.meganewsservers.com...[color=darkred]
>>>> wiped
>>>. Ray O
>>>[/color]
>> car........
>>[/color]
>place under the clamp will help prevent the acid buildup on the posts.[/color]
In a previous life I believe I remember seeing the washer container
with a 'thick' jell in the bottom half of the tank.
Is any old fluid at the store OK these days? Or are specific brands
needed?
So one need special tools and/or knowledge to repair or clean the
washer system? (per manual)
joe
Old 05-29-2006, 02:20 PM   #14 (permalink)
joe
Guest
Posts: n/a
On Mon, 29 May 2006 11:38:36 -0500, "Ray O"
[color=blue]
>news:fl7m729gdrcnnl1ee0p0itgmlbl50g5eo5@4ax.com...[color=green]
>>[color=darkred]
>>>> 1.
>>>socket.[/color]
>> the hood or ??
>>[/color]
>off and the key is in the ignition.[color=green]
>>[/color][/color]
T may have me fooled. It appears that the buzzer is generated and
then sent to the speaker for the radio and CD. Could this be?
If not it sure is packed in there way up under at the center under the
dash.
I just wanted to be able to use the radio etc. with the engine off and
a door open without the buzzer. Perhaps the only possible way is to
have a window open <grin>.
joe
Old 05-29-2006, 02:48 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
news:8dam72le63kpg3slmk6dp3j8tbk7qt0ae3@4ax.com...[color=blue]
><snipped>
> needed?[/color]
While there may be differences between brands of windshield washer fluid, I
just buy the cheapest stuff I can find. You can sometimes find it on sale
in the late spring and early summer for 99 cents a gallon, I buy a case at
that price.
[color=blue]
> joe
>[/color]
I don't think there was any reference to repair or cleaning the windshield
washer system in the owner's manual and they normally do not need routine
service. If you fill the reservoir with tap water, you run the risk of it
freezing and cracking the washer fluid reservoir. You can also dilute the
washer fluid with water during the summer and go back to full strength in
the winter. Washer fluid is inexpensive enough that I always use it full
strength and then I don't have to worry about it freezing.
These days, the washer fluid reservoir on Toyotas is pretty concealed with
only the filler neck visible, and to be honest, I've never inspected the
bottom of the washer fluid reservoir to see what is down there. Servicing
windshield washer reservoirs is probably a hassle because you have to
disassemble quite a bit to get at the reservoir.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Canoe tie-down on 06 Sienna Richard E 2nd Generation (2004-2010) 3 09-04-2006 09:32 PM
04 XLE AWD Limited OR a new 06 Sienna CE ND4SPD_HS 2nd Generation (2004-2010) 6 05-11-2006 02:54 PM
Questions about the new 06 Tacoma Timmons 2nd Generation (2005+) 7 03-03-2006 03:11 PM
2005-06 Sienna AWD Questions cnn 2nd Generation (2004-2010) 3 02-17-2006 07:41 AM
2003 Sienna CE for $10500 with 95,000 miles...Good Buy? sienna716 1st Generation (1998-2003) 2 10-26-2005 11:05 AM
