Corolla - 2003 - Serpetine Belt Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2006, 09:36 AM   #1 (permalink)
John-USN
Guest
Posts: n/a
View John-USN's Photo Gallery
My 2003 has 36K miles on it....however the service manual does not state
when the serpentine belt should be replaced. I always thought every 30 or
50K miles the belt should be changed out.
Anyone know the answer?
Thanks....Regards, John
Old 05-29-2006, 11:37 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Corolla - 2003 - Serpetine Belt Replacement
"John-USN" <mcgriffjt@verizon.net.nospam> wrote in message
news:qNCeg.5505$%C6.2539@trnddc08...[color=blue]
> or 50K miles the belt should be changed out.
> Thanks....Regards, John[/color]
The maintenance schedule for the 2003 Corolla indicates that the drive belts
should be inspected at 60,000 miles and every 15,000 miles thereafter. When
Toyota says that something should be inspected, they mean that the inspected
item should be replaced or adjusted as indicated by the inspection.
If you want peace of mind, just replace the serpentine belt at 60,000 miles.
Ray O
Old 05-29-2006, 12:46 PM   #3 (permalink)
John-USN
Guest
Posts: n/a
Got it Ray----Thanks.....John
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message
news:21c46$447b164a$180fead6$27281@msgid.meganewsservers.com...[color=blue]
> news:qNCeg.5505$%C6.2539@trnddc08...[color=green]
> belts should be inspected at 60,000 miles and every 15,000 miles
> thereafter. When Toyota says that something should be inspected, they
> mean that the inspected item should be replaced or adjusted as indicated
> by the inspection.
> miles.
> Ray O
>[/color]
Old 05-29-2006, 12:59 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:IzFeg.5604$%C6.1492@trnddc08...[color=blue]
>[/color]
You're very welcome! And if the "USN" after your name means that you are or
have served in the USN, THANK YOU!!!
Ray O
Old 05-29-2006, 08:22 PM   #5 (permalink)
John-USN
Guest
Posts: n/a
Yep Ray....still active duty after 22 years.......Thanks for your kinds
words........John
news:e3995$447b2872$180fead6$29402@msgid.meganewsservers.com...[color=blue]
> news:IzFeg.5604$%C6.1492@trnddc08...[color=green]
>>[/color]
> or have served in the USN, THANK YOU!!!
> Ray O
>[/color]
Old 05-29-2006, 09:33 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:ofMeg.2171$hv1.500@trnddc01...[color=blue]
> words........John
>[/color]
Thank you for serving us all those years!
Ray O
[color=blue]
> news:e3995$447b2872$180fead6$29402@msgid.meganewsservers.com...[color=green]
>> news:IzFeg.5604$%C6.1492@trnddc08...[color=darkred]
>>>[/color]
>> Ray O
>>[/color]
>[/color]
Old 05-31-2006, 06:48 PM   #7 (permalink)
BM5680
Guest
Posts: n/a
View BM5680's Photo Gallery
I've got 113K miles on my 2003 and have had no issue with the the belt.
Haven't changed the plugs yet either.
John-USN wrote:[color=blue]
Old 06-01-2006, 07:35 AM   #8 (permalink)
John-USN
Guest
Posts: n/a
Good God....113K on a 2003......that's a lot of driving.
What about the A/C filter under the glove box?
John
"BM5680" <pjacun@gmail.com> wrote in message
news:1149115685.603831.324920@i40g2000cwc.googlegroups.com...[color=blue]
> John-USN wrote:[color=green]
>> or
>[/color]
Old 06-01-2006, 03:00 PM   #9 (permalink)
BM5680
Guest
Posts: n/a
Yes, lots and lots of driving. I change the A/C filter whenever it
looks dirty. I look at it about once a month and tap out the big
stuff. For some reason that filter is hard to find at parts stores and
is a bit pricey from the dealer.
> John
> news:1149115685.603831.324920@i40g2000cwc.googlegroups.com...[color=green]
> > John-USN wrote:[color=darkred]
> >> or
> >[/color][/color]
Old 06-02-2006, 01:21 AM   #10 (permalink)
John-USN
Guest
Posts: n/a
I've never looked at my AC filter.....how hard is it to get to??
news:1149188418.327359.199100@i39g2000cwa.googlegroups.com...[color=blue]
>> John
>> news:1149115685.603831.324920@i40g2000cwc.googlegroups.com...[color=darkred]
>> >> state
>> >> 30
>> >> or
>> >[/color][/color]
>[/color]
Old 06-02-2006, 11:49 AM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:oVPfg.45485$As2.27425@trnddc02...[color=blue]
> I've never looked at my AC filter.....how hard is it to get to??[/color]
The AC filter is usually located behind the glove box. Empty the glove box,
and with it hanging in the open position, squeeze the left and right rear
corners of the glove box so that the stoppers make it past the opening and
the glove box will tilt all the way down. You should be able to see the air
conditioning filter back there somewhere.
Ray O
Old 06-04-2006, 11:09 AM   #12 (permalink)
NBnet
Guest
Posts: n/a
View NBnet's Photo Gallery
For models with no AC is there a filter ?
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:e59d2$44806137$44a4a10d$4762@msgid.meganewsservers.com...[color=blue]
> news:oVPfg.45485$As2.27425@trnddc02...[color=green]
> box, and with it hanging in the open position, squeeze the left and right
> rear corners of the glove box so that the stoppers make it past the
> opening and the glove box will tilt all the way down. You should be able
> to see the air conditioning filter back there somewhere.
> Ray O
>[/color]
Old 06-04-2006, 07:04 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
"NBnet" <mkleggs@REMOVE.nbnet.nb.ca> wrote in message
news:IICgg.17359$A26.402396@ursa-nb00s0.nbnet.nb.ca...[color=blue]
>[/color]
Good question. I have no idea.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 10:06 AM
2003 Corolla windows BenG 9th Generation (2003-2008) 12 11-19-2007 05:23 PM
All 2003 Corolla - Low Washer Light JakeJacobs 9th Generation (2003-2008) 22 10-11-2007 10:09 AM
Does 2000 Corolla Ve has a timing belt? John2000ve Archived Corolla threads 5 02-03-2005 12:44 PM
Belt Changing on 03' Corolla vick Archived Corolla threads 4 01-12-2005 10:24 PM
