Re: Distributor cap O-ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2006, 11:46 AM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message news:...[color=blue]
> "Danny G." <dandog@pacbell.net> wrote in message
> news:_VCeg.19053$fb2.2064@newssvr27.news.prodigy.net...[color=green]
>> My 1987 Supra n/a ignition distributor has/had a O-ring for the cap. It
>> seems to be one of those items I just can not get OEM.
>> Who knows why, probabley 1/2 me idk.
>> How can I find out the correct size of that O-ring so I can just go buy
>> one someplace?
>> I don't want to try guessing because last time I cracked the cap and it
>> was like $40 /no O-ring!
>> Thanks
>> Dan
>>[/color]
> The O-ring used to be available through Toyota dealers as an OEM part.
> Perhaps the age of the vehicle is what is making it hard to find.
> To get the correct size, use a vernier caliper to measure the outside
> diameter of the groove in the distributor shaft. This corresponds to the
> inside diameter of the O-ring, then measure the inside diameter of the
> distributor shaft opening the get the outside diameter of the O-ring.
> Ray O
> (correct punctuation to reply)
>[/color]
Oops! Correction: I was referring to the distributor shaft O-ring and not
the distributor cap O-ring. use the same procedure to get the inside and
outside diameters for the O-ring for the cap.
Ray O
Old 05-30-2006, 03:40 AM   #2 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message news:b63f1$447b173c$180fead6$27565@msgid.meganewsservers.com...[color=blue]
> "Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message news:...[color=green]
>> "Danny G." <dandog@pacbell.net> wrote in message news:_VCeg.19053$fb2.2064@newssvr27.news.prodigy.net...[color=darkred]
>>> My 1987 Supra n/a ignition distributor has/had a O-ring for the cap. It seems to be one of those items I just can not get OEM.
>>> How can I find out the correct size of that O-ring so I can just go buy one someplace?
>>> I don't want to try guessing because last time I cracked the cap and it was like $40 /no O-ring!
>>> Thanks
>>> Dan
>>>[/color]
>> The O-ring used to be available through Toyota dealers as an OEM part. Perhaps the age of the vehicle is what is making it hard
>> to find.
>> To get the correct size, use a vernier caliper to measure the outside diameter of the groove in the distributor shaft. This
>> corresponds to the inside diameter of the O-ring, then measure the inside diameter of the distributor shaft opening the get the
>> Ray O
>>[/color]
> Oops! Correction: I was referring to the distributor shaft O-ring and not the distributor cap O-ring. use the same procedure to
> get the inside and outside diameters for the O-ring for the cap.
> Ray O
> (correct punctuation to reply)[/color]
Last time I still had the original O-ring and found a perfect match. or so I thought. crack.
Darn things only about a toothpick size O-ring 4 1/4" diameter or so.
The real kicker is that I bought the car new and have no valid reason for ever removing the
cap (less plug wires) because it appears to be a lifetime part. A aftermarket cap was history in 10,000 miles.
Oh well :/
BB code is Off
Smilies are Off
[IMG] code is Off
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 07:53 PM
Ring Gear ROBS Camry & Solara Lounge 17 05-07-2006 11:40 PM
A story about my school class ring... epinionator89 Off Topic 6 08-20-2005 07:20 AM
Ring Ring Ring Banana Phone! Tommy Off Topic 15 03-10-2005 08:40 PM
Ring and pinion 1985rollasr5 Archived Corolla threads 5 10-24-2004 01:27 AM
