Toyota Carina. Key stuck in lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2006, 06:07 AM   #1 (permalink)
DDEckerslyke
Guest
Posts: n/a
View DDEckerslyke's Photo Gallery
Hi
The key is stuck in the ignition of our Toyota Carina. The problem is
identical to the one described here
[url]http://tinyurl.com/lqw7x[/url] but as a car novice I couldn't make sense of the
reply and the OP seems to be no longer active. We've been told a new lock
will be roughly GBP200. This is a lot of money. Are there other solutions we
can try? Is there a cheaper way of getting the problem fixed?
cheers
dd
Old 05-30-2006, 08:30 AM   #2 (permalink)
zikkimalambo@connectfree.co.uk
Guest
Posts: n/a
View zikkimalambo@connectfree.co.uk's Photo Gallery
Re: Toyota Carina. Key stuck in lock
DDEckerslyke wrote:[color=blue]
> Hi
>[/color]
Well, I understood part of Mr Cheerful's answer, he was suggesting that
on Automatics there may be a mechanism whereby you can only remove the
key if the slector is in neautral/park. If the switch/circuit that
"tells" the lock that this is the case has failed and it isn't getting
the signal, then it won't allow the key to be removed.
I would ring a few auto electricians/car immobiliser fitters and see
what suggestings they have. If the can't get the key out, perhaps they
could fit some kind of immobiliser so that only you can drive it. You
cauld then leave the key in.
Old 05-30-2006, 11:19 AM   #3 (permalink)
Thor Jan Børresen
Guest
Posts: n/a
View Thor Jan Børresen's Photo Gallery
I did the same thing in Norway and the price was GBP 50,- from the Toyota
dealer.
Check around for a better offer as this is a common weekness of this car.
TJ
<zikkimalambo@connectfree.co.uk> wrote in message
news:1148992220.484505.216570@i39g2000cwa.googlegroups.com...[color=blue]
> DDEckerslyke wrote:[color=green]
>> Hi
>> we
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota to Offer XM Radio as a Factory-Installed Option EKam Toyota News 1 08-17-2011 07:53 PM
surpercharge 3VZ-FE possible? gmfb3VZ-FE Hardcore Tech and Competition 24 04-26-2010 10:24 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 07:54 PM
starter problem sureshot 89-95 Toyota Pickup/Hilux 10 12-14-2006 10:24 PM
