Chance of CD melting in hot climates? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2006, 03:28 PM   #1 (permalink)
joe
Guest
Posts: n/a
View joe's Photo Gallery
Typically I will constantly forget to remove a CD from the player. In
my past the player was located at the bottom of the dash.
On the Sienna 06 it is near the top!
Any case of a CD melting or damaging the player in the hot south or
even north?
j
Old 05-30-2006, 03:34 PM   #2 (permalink)
Travis Jordan
Guest
Posts: n/a
View Travis Jordan's Photo Gallery
Re: Chance of CD melting in hot climates?
joe wrote:[color=blue]
> even north?[/color]
The melting point of polycarbonate is about 250 degrees C. Not to
worry.
Old 05-30-2006, 03:51 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"joe" <nospam@invalid.com> wrote in message
news:ct6p72549icpcm6p2ueksvs977vnlkkaji@4ax.com...[color=blue]
> even north?
> j
>[/color]
Yes, a slim one.
Ray O
Old 05-30-2006, 03:54 PM   #4 (permalink)
joe
Guest
Posts: n/a
On Tue, 30 May 2006 19:34:47 GMT, "Travis Jordan" <no.one@no.net>
wrote:
[color=blue]
>joe wrote:[color=green]
>> even north?[/color]
>worry.
>[/color]
Attempting to recall my properties of materials classes ...
I frequent Palm Springs, CA and 105 deg F is a rule and not the
exception. Air temp inside a car can get well over 150deg F and a
dark dash SHOULD NOT BE TOUCHED without welding type gloves - I will
make a wild guess north of 200degF.
So we have a melting point of 250 - 200 = a small spread. Between
solid and melting we have a very pliable stage ...
Perhaps there is no problem but a check in the real world is generally
a sound idea. If all else fails - ask the mechanic who has lived with
all the design mistakes <grin>.
j
Old 05-30-2006, 04:31 PM   #5 (permalink)
Travis Jordan
Guest
Posts: n/a
> make a wild guess north of 200degF.[/color]
[color=blue]
> solid and melting we have a very pliable stage ...[/color]
Um, no, the melting point is about 250 degrees C. As in Centigrade. Do
the math.
Old 05-30-2006, 04:35 PM   #6 (permalink)
Mark A
Guest
Posts: n/a
View Mark A's Photo Gallery
> even north?
> j
>[/color]
It is theoretically possible that the CD could warp just a bit on a very hot
day depending on how it is stored internally in the CD player. CD's spin a
very high speeds and even a slight warp could cause a problem.
Hopefully the CD player manufacturer has taken this into account, and the CD
is evenly supported so as not warp. I leave mine in all the time and have
never had a problem.
Old 05-30-2006, 04:41 PM   #7 (permalink)
Mark A
Guest
Posts: n/a
"Travis Jordan" <no.one@no.net> wrote in message
news:GY1fg.28067$Mg2.5952@fe08.news.easynews.com...[color=blue]
> the math.
>[/color]
Melting point is not the same as bending point.
Old 05-30-2006, 05:22 PM   #8 (permalink)
joe
Guest
Posts: n/a
On Tue, 30 May 2006 14:35:48 -0600, "Mark A" <nobody@nowhere.com>
wrote:
[color=blue]
>news:ct6p72549icpcm6p2ueksvs977vnlkkaji@4ax.com...[color=green]
>> even north?
>> j
>>[/color]
>[/color]
Travis you are correct C is not F sorry.
Mark - I have an "El Chepo" CD player at my desk where I can observe
the CD rotating. My guess is - very slowly in that I can almost read
the text on the CD as it is rotating.
What is the rpm - anybody?
j
Old 05-30-2006, 06:49 PM   #9 (permalink)
Wickeddoll®
Guest
Posts: n/a
View Wickeddoll®'s Photo Gallery
> even north?
> j
>[/color]
Some here have said it's a hazard, but I used to live in Arizona, the
California desert, as well as my native Florida. I left CDs in the player
all the time, and never had a problem. The only time a CD melted was
outside the player.
Having said that, you should never use original CDs in your car; not only
because of the potential for damage, but also theft, should your car/truck
be stolen. A friend of mine's F-150 was stolen, along with about $300
worth of CDs. She was more heartbroken about that. (Even I think the
truck was more important...)
Natalie
Old 05-30-2006, 07:37 PM   #10 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
It hasn't happened to me. I left a CD in the player of my motorhome without
any problem at all.
> even north?
> j
>[/color]
Old 05-30-2006, 07:46 PM   #11 (permalink)
---MIKE---
Guest
Posts: n/a
View ---MIKE---'s Photo Gallery
The speed of a CD varies depending on the diameter being read - faster
near the center and slower at the outer edge. I'm not sure but I think
it goes from 200 to 600 RPM.
---MIKE---[color=blue][color=green]
>>In the White Mountains of New Hampshire
>> (44° 15' N - Elevation 1580')[/color][/color]
Old 05-30-2006, 08:08 PM   #12 (permalink)
Built_Well
Guest
Posts: n/a
View Built_Well's Photo Gallery
> What is the rpm - anybody?[/color]
Not positive, but I think 1X for a CD is between 150 and 160 RPM.
Old 05-30-2006, 08:18 PM   #13 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:958p72lk3hckqu4nj4rh4nl03c8a4gqfa5@4ax.com...[color=blue]
> wrote:
>[color=green]
>>joe wrote:[color=darkred]
>>> even north?[/color]
>>worry.
>>[/color]
> j[/color]
It's safe to assume that the INSIDE of the CD player does not get to 250F.
Old 05-31-2006, 08:54 AM   #14 (permalink)
=?iso-8859-1?Q?mark=5Fdigital=A9?=
Guest
Posts: n/a
View =?iso-8859-1?Q?mark=5Fdigital=A9?='s Photo Gallery
> even north?
> j
>[/color]
You're more likely to screw things up if you don't know there's a CD in the
player already.
mark_
Old 05-31-2006, 04:27 PM   #15 (permalink)
Ernie Sty
Guest
Posts: n/a
View Ernie Sty's Photo Gallery
"Mark A" <nobody@nowhere.com> wrote in message
news:0cOdnahUCLx-MOHZ4p2dnA@comcast.com...[color=blue]
> news:GY1fg.28067$Mg2.5952@fe08.news.easynews.com...[color=green]
>> the math.
>>[/color]
> Melting point is not the same as bending point.[/color]
250 C is over 480 F. Even if it could somehow get up to 250 F inside a
car CD player (way more than hot enough to boil water, and the parts of the
car in direct sunlight would have to be much hotter) it would still be 230
degrees colder than the melting point of polycarbonate. Usually, warping or
bending points are relatively close to melting points. I doubt it would
ever get up to 250C in the CD player, even in the middle of the Sahara on
summer solstice. Heat radiation and convection of the air (even if the air
is 130 degrees) would be very significant. But even if it did, the CD is
still 230 degrees cooler than melting point, so it probably hasn't even
started to soften at that point.
BB code is Off
Smilies are Off
[IMG] code is Off
Scion VIP @ Hot Import Nights - Boston - April 30, 2005 ScionVIP Scion Events 3 04-11-2005 03:16 PM
Talib Kweli's new CD= HOT! Erbe Off Topic 23 12-21-2004 06:05 PM
